Valvetrain hardware question?
I plan on putting LE2 heads and a CC503 cam in my 1996 Vette A4.It has dual valve springs springs on the heads now but I dont want to use them cause I think they have to much seat pressure for my application and plus the guy I got them from dont know much about the hardware on the springs.I went and bought some beehive,26918-16 springs.My question is what retainers,locks,seats and shims do I need to get the correct install height?If you have a similar install please tell me about it so I can make a good decision on my setup.Any input would be helpful.......Thanks
Beehive Info
If you want to go with 7 degree hardwarde:
787-16 retainers
648-16 locks
stock or LT4 spring seats
If you want to go with 10 degree hardware (super locks):
795-16 steel retainers, or
794-16 titanium retainers
611-16 locks (standard), or
614-16 locks (+.050)
4705-16 spring seats
Using the 7 degree hardware and stock spring seats you
should end up with an installed height close to 1.78". With
10 degree hardware, 4705-16 spring seats, and the +.050
super locks you should see a 1.75" installed height.
787-16 retainers
648-16 locks
The question doesn't make much sense to me. You need to use shims to set the installed height, it isn't set by choice of other components (unless there isn't enough height and you need plus retainers, etc.). You are really going about it backwards by not starting with the retainers and locks you plan to use and measuring the amount of height you have to work with. Once you know that, you can select springs.
Rich
Rich
I wouldnt use them if I got them given to me for free. It's just my opinion, but I have seen alot of broken beehives, I cant justify the risk of running them for whatever "gain" they are worth.
Motor vs grams...
-Dustin-
Motor vs grams...
-Dustin-
Would these be a better choice?These are already on the heads and set at 1.85 spring height. Crane Cams
Manufacturer's Part Number 10308-1
Part Type Valve Spring and Retainer Kits
Product Line Crane Valve Spring and Retainer Kits
Summit Racing Part Number CRN-10308-1
Number of Springs Per Valve Dual
Outside Diameter of Outer Spring (in) 1.460 in.
Damper Spring Included No
Spring Rate (lbs/in) 408 lbs./in.
Inside Diameter of Outer Spring (in) 1.075 in.
Inside Diameter of Inner Spring (in) 0.803 in.
Valve Spring Style Standard
Coated No
Retainers Included Yes
Retainer Material Steel
Locks Included Yes
Lock Style 7 degree
Lock Groove Quantity 1-groove
Lock Material Steel
Quantity Sold as a kit.
Coated No
Locks Included Yes
Lock Style 7 degree
Lock Material Steel
Coated No
Locks Included Yes
Lock Style 7 degree
Lock Material Steel
Coated No
Locks Included Yes
Lock Style 7 degree
Lock Material Steel
-Dustin-
Good luck getting those springs with Crane out-of-business. S&S cycle bought them but haven't filled all the back orders yet.
Anyway, those springs are an OK choice for the 503 cam. Comp wants 130 #/in seat pressure, these have 120 #/in but that's rated at an installed height of 1.875", not the LT-1 target of 1.78", Comp wants an open pressure of 318 #/in at a compressed height of 1.2", these springs are rated at 394#/in but that's at a compressed height of 1.175 #/in. I'm guessing these springs would be pretty close to spec if they were measured the same way.....
Do you use a different timing set cause I plan on using my stock one and am going to change the chain out.Will those springs put to much pressure on the stock timing set,10308-1?
