which valves springs?
Old Jan 21, 2008 | 07:00 PM
  #16
The Engineer's Avatar
Originally Posted by pkozera
My question is why are you trying to spin that cam above what comp says its rpm range is witch is 2200 to 6200 rpms?
Taking it to slightly over 6500, with a rating of 6200 RPM really isn't really that significant (only 300 additional RPM), also my heads are a factor. Additionally, the Comp rating of 6200 RPM is probably on the conservative side. If I was going for 7K, that would be an issue.
WD
Old Jan 21, 2008 | 07:14 PM
  #17
speed_demon24's Avatar
WD
Your extra 46 cubic inches also shifts the power band down alot over a 350 c/i motor. A stock cube motor wouldn't be able to rev high enough to take advatange of that cam with the stock pcm, and thats assuming you can control the valvetrain.
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
nikolt1
Feb 27, 2015 09:10 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
