Valve springs/seats/retainers/valve locks
Old Nov 9, 2002 | 04:19 AM
  #16
Ai's Avatar
Ai
If youre going to have to machine the seats though, you might as well run something nice instead of that crane stuff with the dual spring w/ no damper etc.
Whoever does your heads should know what to do...
Old Nov 11, 2002 | 01:57 AM
  #17
blown383's Avatar
From what I read the 10308-1 kit doesn't require machining of the seats, you can just use the L98 seats. I'm assuming the 987/986/985 springs need machining with the 4771 locators right?
The thing is I would like to run the cam on stock heads till the heads are done. Would this be wise or should I really just wait till I have everything together?
-B
Old Nov 11, 2002 | 02:23 AM
  #18
onebadponcho's Avatar
Go on Crane's website. I know it will say in the write-up for the spring/retainer package that it will fit stock spring pockets, but they won't. If you look, you'll find that the spring part # 99893 is a 1.46" dia. spring. With the cam you plan on running, I don't think there's going to be a way around using bigger valve springs.
Old Nov 13, 2002 | 12:10 PM
  #19
blown383's Avatar
Are you sure?
-B
Old Nov 13, 2002 | 03:12 PM
  #20
Originally posted by blown383
Are you sure?
-B
No, but now I am. Crane makes two spring kits for our cars: part # 10308-1, which will fit stock valve pockets; and part #10308, which will not. Here's another post on the subj. of valvesprings (I boo-booed on that one too).
http://web.camaross.com/forums/showt...threadid=46182
Old Apr 1, 2003 | 05:54 PM
  #21
MSM69Z28's Avatar
i just picked up a set of the 730-16 titanium retainers and 613-16 10 degree locks for my 500# open springs.
question though. these retainers don't say they are .050" taller installed height. some titanium retainers are. anyone know if these should result in standard installed height.
i have the springs set up just right for my solid roller and i would hate to have to shim them all to keep up the pressure for this set up.
any help on these retainers and locks appreciated.
thanks,
mike
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
MadMav
Jun 15, 2015 09:51 PM
Roadie
Feb 16, 2015 10:34 AM
