valve springs & rockers
Old Nov 13, 2006 | 09:22 PM
19z28camaro02's Avatar
Question valve springs & rockers
need a little bit of help in selection, what do i need to look for, what should i stay away from?
Old Nov 14, 2006 | 10:48 AM
Z-RATED94's Avatar
Get some CompCam 1.6 full roller rockers, non self aligning. A set of hardened pushrods and a set of GMPP guideplates. Then you need a set of HotCam springs and a tune from madz28.com, a sponser. Should be worth about 25 to 30 hp.
Old Nov 14, 2006 | 12:17 PM
CustomSSI's Avatar
Sounds good.. I'd like to add that if you are planning on doing a cam in the new future maybe some different springs but otherwise thats everything you need.. Shoot us a PM if you'd like some pricing...
Josh
Old Nov 15, 2006 | 11:21 AM
Z-RATED94's Avatar
Josh
Good advice. If you want to do it right, go with the 7/16th rockers and studs, buy the CompCam Hi Tech pushrods and get a set of 918 beehive springs. That way you will be set if you throw a cam in it.
Old Nov 15, 2006 | 11:38 PM
JP95ZM6's Avatar
Just a thought regarding longevity. Aluminum rockers have a fatigue life that could come into play within the life of your engine if you keep it a long time, and I have been told to 'check them regularly'. However, I don't think you can non-destructively check fatigue cycles, and by the time a crack appears I think breakage is going to happen very very soon. to be safe, I am electing to get the Pro Magnums instead. Steel, and should last a lifetime, more or less. The flipside is that I think the LT4 came with aluminum rollers (Golds), so in that application they must be OK.
Anybody ever break an aluminum rocker body? Anybody have 100k miles on em?
Old Nov 16, 2006 | 07:22 AM
rskrause's Avatar
Moderator
I like aluminum rockers.
Rich
Old Nov 16, 2006 | 06:10 PM
JP95ZM6's Avatar
I am starting to think I got bad advice about needing to change them out. I asked around at work and started a post, and can't find anybody that ever broke one without also having other valvetrain issues. Must be ok. Fatigue concern retracted.
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
