Trouble after upgrades
Old Nov 16, 2006 | 06:17 PM
Greaseymec's Avatar
Having some trouble after a few bolt on mods. Changed to a ported intake and 58MM TB. Installed Jet Hot long tubes and a X pipe set up. Also swapped out the Comp Rs for a new stock set of lifters. 1/4 turn adjustment after 0 lash. (comps were to damn noisy) Car ran fine when I first cranked it after the mods. Lots of improvement! After it gets warm and is driven for a while, it starts popping under less than moderate acceleration. When I approach a stop light, I have to do the right foot on the gas and the left foot on the brake kinda thing to keep it running. When its shut off (or dies) and I try to restart it, it kicks back like its waaayyyy to advanced. (broke a starter housing) I disconnected the coil wire to troubleshoot any mechanical or some sort of liquid lock. I cranks over fine, but when I reconnect the coil wire, it kicks back. At the moment, it will not start. Plugs are gapped at .050. The scanner shows no codes. Help!
Mec
Old Nov 16, 2006 | 07:55 PM
94/96ZsM6s's Avatar
adjust your idle using the adjust ment screw on the TB. with my 396 and BBK 58TB. mine would die at every stop light, and woudl never idle. after opening the blades of the TB slightly more with that adjustment screw the problem went away. hope fully this helps or you have greater isues
Dustin
Old Nov 16, 2006 | 07:59 PM
Greaseymec's Avatar
That helped at first. But when the car starts to warm up is when the problems start. Runs great cold.
Mec
13qtr
Oct 28, 2016 08:11 PM
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Tarizza
3rd Gen / L98 Engine Tech
Sep 20, 2015 03:26 PM
