valve springs
Old Dec 24, 2010 | 04:09 PM
blackedoutZ's Avatar
valve springs
i need some advice on valve spring selection i will be running a cc306 with 1.6rr's i thought about going with the patriot dual gold spring kit i believe it comes with new locks and everything, 8401-BSBC is the part number will these work well with the cc306?
Old Dec 24, 2010 | 05:07 PM
Bersaglieri's Avatar
Re: valve springs
Not trying to be a jerk, but a search will turn up more results that you'll see posted over the next few days. Everything from PAC beehives to Crane 10308-1 to PG-Extremes, to K800's to Comp 977's can and have been used.
-Dustin-
Old Dec 24, 2010 | 05:33 PM
RamAir95TA's Avatar
Re: valve springs
Also do a search on the 306. It's outdated and there are far better options.
Or are you picking it because it's "big and sounds good?" Stupid YouTube.
Old Dec 25, 2010 | 03:50 PM
Re: valve springs
i have done some searching and from what i have found the patriot kit will work ive found that alot of people prefer this kit i just wanted a second opinion and also i appreciate you not being a dick like a lot of people are it really pisses me off when you are trying to get some advice and everyone has to be a dick they act like if you havnt done it before then you shouldnt even attempt to build a car
Old Dec 25, 2010 | 03:56 PM
RamAir95TA's Avatar
Re: valve springs
Don't know if you're directing that at me or not, but it's still valid advice. Just a suggestion.
Old Dec 26, 2010 | 11:34 AM
Re: valve springs
that wasnt directed toward you at all man, and i appreciate the advice i was just stating how some people are dicks when you ask for advice
Old Dec 26, 2010 | 12:33 PM
SmokeyBlaZe's Avatar
Re: valve springs
http://www.youtube.com/watch?v=D7oldCq96Os
Old Dec 26, 2010 | 06:53 PM
Re: valve springs
not bad for stock heads
Old Dec 26, 2010 | 09:17 PM
bowtiedad_z28's Avatar
Re: valve springs
I am stock headed with my 306 at the moment and dynoed 351/350. Heads will be coming soon. I do agree there are better cams out there but the 306 is a proven cam even though it is old technology. I am not complaining about mine.
Old Dec 29, 2010 | 09:52 AM
GenIIJR's Avatar
Re: valve springs
Here is some info...
https://www.camaroz28.com/forums/sho...d.php?t=779042
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
nikolt1
Feb 27, 2015 09:10 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
