valve springs
valve springs
i need some advice on valve spring selection i will be running a cc306 with 1.6rr's i thought about going with the patriot dual gold spring kit i believe it comes with new locks and everything, 8401-BSBC is the part number will these work well with the cc306?
Re: valve springs
Not trying to be a jerk, but a search will turn up more results that you'll see posted over the next few days. Everything from PAC beehives to Crane 10308-1 to PG-Extremes, to K800's to Comp 977's can and have been used.
-Dustin-
-Dustin-
Re: valve springs
i have done some searching and from what i have found the patriot kit will work ive found that alot of people prefer this kit i just wanted a second opinion and also i appreciate you not being a dick like a lot of people are it really pisses me off when you are trying to get some advice and everyone has to be a dick they act like if you havnt done it before then you shouldnt even attempt to build a car
Re: valve springs
