valve springs
Old Jan 8, 2006 | 07:08 PM
sevans327's Avatar
valve springs
I am working on another lt1. I was wondering if I can get away with running the lt4 hot cam springs with a comp 224/230 cam? I have them on the heads now but not sure if the lift is going to be to great? Any help would be great.
Shawn
Old Jan 8, 2006 | 07:38 PM
RE AND CHERYL's Avatar
Re: valve springs
Whats the lift on that cam??
LT4 springs are only good to .525
Old Jan 8, 2006 | 08:19 PM
WS6T3RROR's Avatar
Re: valve springs
I dont think the hotcam springs have a chance of handling that, for one theres most likely not going to be enough clearance to bind on the spring. and for two theres no way theres enough spring pressure to control an xe lobe with the hotcam springs.
Old Jan 8, 2006 | 08:35 PM
TransAm396's Avatar
Re: valve springs
my friend ran a cc306 with LT4 springs..and stock rockers..so i dunno..it should work.
Old Jan 8, 2006 | 08:55 PM
FastZinTennessee's Avatar
Re: valve springs
I've heard quite a few times that the LT4 springs are marginal for the HOTcam. Seems that the .525 lift figure that the HOTcam has is right at the limit for the springs.
Even if your 224/230 has similar lift figures, I'm sure it has more aggressive ramp rates making valve control even more of an issue. I know it's a pain but you really need to get a better set of valvesprings.
Old Jan 8, 2006 | 09:01 PM
96flame's Avatar
Re: valve springs
The last thing you wanna do is break a valve spring and drop a valve. Ever heard the term pay me now or pay me later? You choose but springs are really cheap compared to a rebuild.
Old Jan 10, 2006 | 08:15 PM
Wckd94Z's Avatar
Re: valve springs
you can buy my new 987 springs with retainers for 100 shipped all you need are locks
Old Jan 10, 2006 | 08:29 PM
SStrokerAce's Avatar
Re: valve springs
Good advice
DO NOT SKIMP ON VALVE SPRINGS, it's about the worse thing you can do in a motor.
Old Jan 10, 2006 | 09:31 PM
truedualws6's Avatar
Re: valve springs
Don't use the LT4 springs with the CC503.
Old Jan 10, 2006 | 09:57 PM
Wckd94Z's Avatar
Re: valve springs
TreudualWS6 has an incredible guide for using Comp 918s I followed it and I love them with my CC306, search for it, I got slightly used 918s and hardware for like 150...
Old Jan 10, 2006 | 10:40 PM
TransAm396's Avatar
Re: valve springs
Yeah i got the beehive springs too..im going to send Lloyd my heads and the springs..and hes going to port and put them on..cant wait.
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
nikolt1
Feb 27, 2015 09:10 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
