valve springs
Old Nov 29, 2004 | 12:12 AM
camaroKid223's Avatar
valve springs
i need some .600 valve springs. im a cheep college kid what should i get?
Old Nov 29, 2004 | 01:05 AM
TransAmGT's Avatar
Re: valve springs
EX-612-16
http://www.cmotorsports.com/93-97-fb...ine-valvetrain
Old Nov 29, 2004 | 01:09 AM
Z95m6's Avatar
Re: valve springs
I personally would run some Comp 987's. They are a dual spring so they will be better for valvetrain stability. They also will fit stock heads with out machining. I've seen it done.
Old Nov 29, 2004 | 01:21 AM
TransAmGT's Avatar
Re: valve springs
Oh yea...forgot about those...i'll probably be getting those with the cam 847 i found
So these are good for stock heads and seats and everything? Why are they so cheap?
Old Nov 29, 2004 | 01:25 AM
Z95m6's Avatar
Re: valve springs
The 847 has lots of lift. If you run it with 1.6 RR's i believe the lift is close to .595 if i remember correctly. Thats cutting it to close for me. I would at least want a spring good to .625. I believe the closer you run a spring to the limit the shorter the life it has. The problem with the 987's is that they come with huge seats, bigger than whats needed for the springs. You just have to notch a small corner off each seat so that they will sit flush against the head. This won't effect anything. My buddy did this on his 987's on his car probably 20k ago and everything is still fine on it.
Old Nov 29, 2004 | 12:29 PM
Compstall's Avatar
Re: valve springs
K-Motion K800's are cheaper, and can be found in a Jeg's or Summit catalog.
Old Nov 29, 2004 | 12:45 PM
SVThuh's Avatar
Re: valve springs
I may have some Comps for sale... They were good with my cam (.587/.600)
Never experienced any float, even up at the 6500-6800 rpm range..
Make me an offer... I can have pics for you soon if you like...
Old Jul 29, 2005 | 04:50 PM
CamaroGuy22's Avatar
Re: valve springs
I can't find the EX-612 on the list of springs with that link?
Old Jul 29, 2005 | 05:03 PM
jerminator96's Avatar
Re: valve springs
I'm finishing up my valvetrain setup with an 847 cam and comp 987 springs, I'll tell you how it works out for me.
Old Jul 29, 2005 | 06:50 PM
Re: valve springs
Awsome, can't wait.
Old Jul 29, 2005 | 09:07 PM
SStrokerAce's Avatar
Re: valve springs
The most effective springs for .600" lift that cost the least to run are the Comp Beehives. I will not run the 612's over about .570 lift because they don't have enough seat pressure otherwise.
Once you count all the new parts you need to run and the Ti retainers to get a dual spring to work correctly they add up to more money in the long run.
Not that I know anything about valvetrains..... just make these hyd roller things go to 7500rpm without float.
Bret
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
nikolt1
Feb 27, 2015 09:10 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
