valve spring tolerances
Old Feb 23, 2010 | 02:19 PM
deerslayinrenek's Avatar
When installing the valve springs (comp 918's with a .563 lift cam), what is an acceptable tolerance for the installed height?.....Thanks
Old Feb 23, 2010 | 06:37 PM
Kevin Blown 95 TA's Avatar
I actually measured the spring rate on some of those and found that .035 was about 10#.
Old Feb 23, 2010 | 09:11 PM
MachinistOne's Avatar
Ideally the valve job should be shot with the seats within .005" of each other, that's not hard to do at all. So I would then say your max variance is ~.007"-.008"" because if you have 1.800 and 1.810 you can shim the second to 1.795", same the other direction with the first .015" shim size
Old Feb 23, 2010 | 11:39 PM
ok that makes sense, Thank you!
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
nikolt1
Feb 27, 2015 09:10 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
