Valve spring shims
Old Mar 28, 2009 | 09:34 PM
95 WHITE TRANS's Avatar
Valve spring shims
Hi do i need to order from summit or will any shim do?
THANKS
Old Mar 28, 2009 | 09:43 PM
87bandit's Avatar
depends how much you need to shim
must be slightly larger than the interior and exterior diameter of the spring
Old Mar 28, 2009 | 09:51 PM
rskrause's Avatar
Moderator
They should be placed under the spring locater (cup). If you use them directly under the spring, they need to be hardened shims. Under the cup, they needn't be hard, I suppose. But shims sold as spring shims are typically hardened anyway.
Rich
Old Mar 28, 2009 | 10:31 PM
MachinistOne's Avatar
You'll pay twice as much and most likely get the wrong thing if you order from summit - get them from a machine shop. --> .562 ID x ~1.260" OD - I don't remember the part number for that size off the top of my head.
The copper colored .060" shims are not hardened, the blue/silver .060" & .030" shims are hard as are the black .015" shims.
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
nikolt1
Feb 27, 2015 09:10 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
