valve spring life with ~.600 lift
Old Mar 26, 2004 | 02:13 PM
boosted-lt1's Avatar
Wondering what typical mileage is for a spring with valve lift of around .600.
thanks.
Old Mar 26, 2004 | 02:49 PM
teke184's Avatar
stock springs or springs designed for it?
Old Mar 26, 2004 | 03:07 PM
97 RedSS's Avatar
Im really not sure but I know I have over 10k on mine w/ no problems..
Cody
Old Mar 26, 2004 | 03:19 PM
rskrause's Avatar
Moderator
I would reccomend either premium springs or frequent checking/changing if you are getting to this lift range. Maybe every 5-10,000 miles.
Rich Krause
Old Mar 27, 2004 | 02:54 PM
Thanks guys. The reason for asking is because I plan to run around .580 lift or so. Sounds like it should be no problem, being as I put around 3Kmiles on the car every summer/fall.
thanks again.
scott.
Old Mar 27, 2004 | 02:58 PM
4drLT4's Avatar
Running a CC914 spring with a .622/.640 hyd cam. 8k miles so far....so far so good. Will check pressures in another 1k miles or so.
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
Red_94Formula
Jan 22, 2015 12:17 AM
