could any let me know which springs can be installed without removing the heads? they need to be able to handle .570 lift. will the 987s or cranes work?
All valve springs can be removed and replaced without removing the heads (heads-on valve spring replacement). Do a search on the subject. The Crane valve spring tool is the best.
im not really too familar with springs? are there any better options for springs? something good for the 6500 range. trying to set up a good valvetrain and already have everything else
could someone maybe post up part #s for springs/retainers/locks and whatever else i need to swap the springs? this is the only part holding me back for my cam swap
None at all. I also installed these springs with my heads still on the motor. Look the part number up on summit racing or jegs. The whole kit cost as much as most charge just for the springs.
