Gasket Set For Rebuild?
Old May 22, 2008 | 09:57 PM
ENRKyle20's Avatar
I cant seem to find a gasket set for my rebuild?.. does anyone sell a complete set?..
I can find individual gaskets just not the set.
Is there anything more that I need that this?
Head Gaskets (Does it matter than im 30/1000's over?) (also, Can I use somehting small to raise compression alittle, its a 383 so I dont know)
Exhaust Header Gasket (Does It matter that I have Pacesetters?)
Front Timing Cover Gasket
Optispark seal
Crank seal
Water Pump Drive Seal
Throttle Body Gasket (what size is stock?)
Valve Cover Gaskets
Water Pump Gaskets
What can I reuse?.. Oil pan gasket is rubber and in good shape so I assume I can reuse that. I didnt check but I bet the valve cover gaskets are rubber and reusable?
am I misshing anything.
I am ordering threw jegs, so if anyone can find a gasket set there that would be great, otherwise I can order form anywhere.
Old May 22, 2008 | 10:01 PM
ENRKyle20's Avatar
actually I found one on ebay. its a brand I have heard about before when searching, any good?.. hows the price compare?. Is this EvErYtHiNg I will need?
http://cgi.ebay.com/ebaymotors/1992-...spagenameZWD1V
Old May 22, 2008 | 10:27 PM
bombebomb's Avatar
All head gaskets are 4.125 for the lt1, so your fine there. The valve cover gaskets are rubber. Last time I pulled the valve cover, I did not replace the gasket.
Old May 22, 2008 | 10:53 PM
pcgamer4life's Avatar
Autozone has them for like $125 I think, under "Head Gasket Set."
Old May 23, 2008 | 06:48 AM
You will probably come out cheaper by buying only what you need.
Old May 23, 2008 | 07:10 AM
2000GTP's Avatar
Thats not a bad price for that set. As Shoebox suggested, people have saved money by buying them seperately.
Old May 26, 2008 | 11:11 AM
ENRKyle20's Avatar
the cheapes I can find a autozone is 209.. I think I will buy only what I need. Am I missing any? Also, is there any brands I should get?
Need:
Head Gasket Set = $44.99 (Mr.Gasket)
Intake Manifold Set = $17.99 (Spectre)
Exhaust Flange Gaskets = $14.99 (Percys)
Throttle Body Gaskets Kit = $10.99 (BBK)
Water Pump Gaskets = $1.99 (FelPro)
Rear Main Seal = $21.99 (FelPro)
Timing Cover Gasket = $9.99 (OEM)
OptiSpark Seal = $12.50 (OEM)
H2O Pump Drive Seal= $11.50 (OEM)
$146.93
DONT NEED:
EGR Gaskets (Deleted, Bought Block Off Plates)
Oil Pan (Rubber)
Valve Cover (Rubber)
Old May 26, 2008 | 11:21 AM
Not sure why you don't need an oil pan gasket if you are doing a complete rebuild. You should always replace it. There was a post not long ago that had a link to a pan set that included pan and all timing cover and water pump gaskets & more and was a bargain. It could save you some money.
....I found the link....
http://www.partsamerica.com/ProductD...tNumber=CS9966
Old May 26, 2008 | 12:08 PM
ENRKyle20's Avatar
thank you for that link. I just figured it was rubber and it looks in good shape.. but yeat. thats a good deal. I will pick that up.. free shipping to!
is there anything in my list I missed?
Old May 26, 2008 | 02:15 PM
Partsamerica is the internet outlet for Advance Auto. If you have a store in your area, you can just go get one from them.
Old May 26, 2008 | 02:16 PM
ENRKyle20's Avatar
it was free shiping, saves me a trip.. but thanks for the info.
I ordered everyhthing except the valve cover gaskets. and saved about $30 or so, not bad, but it was about 30 mirs of searching for best prices and finding everyrthing I need, it was worth it.
Thanks for all the help!
Sergio
Jan 27, 2016 04:27 PM
Jazsun
Dec 29, 2014 12:14 PM
Brandon Wittmer
Dec 8, 2014 07:53 PM
