valve spring ?
Old May 25, 2008 | 05:08 PM
z28maro's Avatar
valve spring ?
could any let me know which springs can be installed without removing the heads? they need to be able to handle .570 lift. will the 987s or cranes work?
Old May 25, 2008 | 05:49 PM
The Engineer's Avatar
All valve springs can be removed and replaced without removing the heads (heads-on valve spring replacement). Do a search on the subject. The Crane valve spring tool is the best.
WD
Old May 25, 2008 | 05:57 PM
z28maro's Avatar
i thought some springs required machining to install correctly?
Old May 25, 2008 | 06:09 PM
MeanGreen97Z's Avatar
Some do... you need to find one with stock diameter. Crane 10308 is a good spring handling up to 600 lift.
Old May 25, 2008 | 06:25 PM
z28maro's Avatar
im not really too familar with springs? are there any better options for springs? something good for the 6500 range. trying to set up a good valvetrain and already have everything else
Old May 25, 2008 | 07:38 PM
What cam?
Old May 25, 2008 | 09:51 PM
z28maro's Avatar
306 but may change it out for a slightly higher lift/less duration custom cam in a few months when it comes back apart. .570 lift max ever at the most
Old May 26, 2008 | 12:13 PM
z28maro's Avatar
could someone maybe post up part #s for springs/retainers/locks and whatever else i need to swap the springs? this is the only part holding me back for my cam swap
Old May 26, 2008 | 12:22 PM
Slowmaro95Z28's Avatar
I just did a 306 swap. I used the Crane 10308 kit. It came with everything I needed and they work great.
Old May 26, 2008 | 12:24 PM
z28maro's Avatar
you didnt have to do any machining or anything?
Old May 26, 2008 | 12:26 PM
None at all. I also installed these springs with my heads still on the motor. Look the part number up on summit racing or jegs. The whole kit cost as much as most charge just for the springs.
Old May 26, 2008 | 12:39 PM
z28maro's Avatar
thanks for the input i think thats what ill do the ....10308 kit. do i need new locks or will the stock ones work fine?
Old May 26, 2008 | 12:40 PM
It comes with locks. As I said, it's a complete kit.
Old May 26, 2008 | 12:45 PM
z28maro's Avatar
o awesome thanks thats all i needed to know
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
nikolt1
Feb 27, 2015 09:10 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
