Vacuum / PCV system bugs
Old Dec 23, 2008 | 12:26 AM
JoeliusZ28's Avatar
Ok this past season i cammed my car and Im trying to work out the bugs now.
The problem I am having is poor vacuum and Id like to know if this is typical or if there is a problem somewhere. The cam is a 226/234 w/ 110 degree LSA so i expected some vacuum loss. That being said my brakes were quite noticeably weaker, my HVAC controls no longer work, and my PCV system doesnt appear to be working because i found some white "frothing" on the top of my valve cover. I have verified the PCV check valve to be A-O-K, and everything worked on the car prior to the swap - even the underside of the valve covers were spotless.
I was less than confident reinstalling some of the miscellaneous "plumbing" on my intake after the swap even though i took several pictures of everything before the teardown. I recall some fittings that remained vacant, and im not sure if they were always this way or not.
Basically id like to know if my vacuum loss is normal, or did i mess something up creating a vacuum leak? ...Just so i know where to start, thanks!
Old Dec 23, 2008 | 05:18 AM
From a scan, at idle, what is the MAP reading and what is the barometer reading? The difference between those two is the manifold vacuum.
Old Dec 23, 2008 | 08:29 AM
...or you could just stick an old fashioned vacuum gauge on it.
Old Dec 23, 2008 | 02:09 PM
JoeliusZ28's Avatar
thanks, ill pull up one of my old log files later today and get back.
Old Dec 23, 2008 | 07:52 PM
twcblackhand6970's Avatar
so putting a big cam will make a/c and heater not work?
Old Dec 23, 2008 | 09:22 PM
nb 96 z's Avatar
They will still work. It would have to be a problem with your a/c system or heater core for those not to work.
Old Dec 23, 2008 | 09:23 PM
The AC and heater will continure to work just fine. The problem is the flapper doors in the ductwork for the AC and heat are actuated by engine vacuum. If vacuum is low, the doors may not operate correctly. There is a vacuum reservoir in the system that controls the HVAC doors, and a check valve to allow it to "store" vacuum when its high.
Old Dec 23, 2008 | 10:08 PM
okay, that scared me.
Nickster 7
May 1, 2015 09:04 PM
mmf_1013
Apr 11, 2015 11:03 PM
lt1matt
Mar 21, 2015 07:35 PM
grgguy
17
Feb 23, 2015 07:57 PM
CARiD
Jan 27, 2015 06:27 AM
