Using a PCM program downloaded from another
Old Apr 21, 2004 | 08:21 PM
Tim240z's Avatar
I'm assuming it's ok, but though I would double check here:
Are there any problems with reading teh PCM from one car and downloading it to another. Both are from 1994 Z28s (M6), only one is bone stock (still in a Z28) and the other has been 'tinkered with' and is in a 240Z. The stumble problem I have with the 240Z is making me scratch my head a bit, so I though I would try this....
Tim
Old Apr 21, 2004 | 08:27 PM
Shouldn't be a problem. Not really any different than modifying your own bin or flashing to an aftermarket tune.
Old Apr 21, 2004 | 08:33 PM
Tim240z's Avatar
As always...Thanks Rob!!!
Old Apr 21, 2004 | 09:12 PM
scoobysnax83's Avatar
you will be fine, I just did this. In fact, I got the opposite results...
Old Apr 21, 2004 | 09:15 PM
bunker's Avatar
Just tune the 240z lt1 PCM in your 94 Z28?
Old Apr 21, 2004 | 09:21 PM
Tim240z's Avatar
I just can't see that this low RPM stumble is a PCM tune issue....I mean it's not like a 4 barrel double pumper...the PCM ca't just lose it's tune.
I just want to check that I haven't screwed something up while screwing around in TunerCat.
I guess I could just use the 'compare' function in TunerCat with the two programs....
I also am going to install the new 30lb injectors (with PCM change of course), do a compression test, and replace the fuel pump...after that EVERY component will have been changed, or tested......IF that doesn't work...out comes the LT1 and in goes a twin turbo 4 bolt with Tek 3!!!!!
Aug 24, 2015 06:41 AM
4586
Aug 18, 2015 07:08 AM
whitehooptie
Aug 10, 2015 07:02 AM
4586
Aug 2, 2015 01:45 PM
88IROC_Z
Jul 22, 2015 11:38 PM
