Urgent what does this code mean!!!!!!1
Old Jul 26, 2003 | 05:56 PM
TexasTechTA's Avatar
DTC P0372 - IC 24X Reference Circuit Missing Pulses
my car si taking a long time to start and runs bad when cold help me please.
Old Jul 26, 2003 | 05:59 PM
Camaro_Maniac63's Avatar
i think that means your opti is crapping out on you. i am not sure though.
Old Jul 26, 2003 | 06:08 PM
anyone else I am desperate is the IC stand for igniton control or igniton coil?
Old Jul 26, 2003 | 06:28 PM
moparman's Avatar
It has to do with an erratic low res signal from the opti. Start by checking all connections. Probably will be the opti, unfortunately.
Of course I could be wrong. It wouldn't be the first time.
Edit: it has to do with the high res signal, not low.
I saw the other thread, and the opti appears to be the culprit.
P0372 Timing Reference High Resolution Signal A Too Few Pulses
here is more info on the code
Old Jul 26, 2003 | 09:10 PM
okay for all you guys that had optis go otu did it throw this code or what? if mine was out wouldn;t it misfire all the time and run bad even when warm right?
Old Jul 26, 2003 | 10:05 PM
what are the most common problems of a failing opti?
Old Jul 27, 2003 | 12:50 AM
You really ought to keep all these questions in a single thread, since they are all about the same problem and the same subject. People trying to answer a bunch of threads posted in scattergun fashion are not going to have the benefit of the previous responses regarding the problem. I've posted to a couple of your threads, and this one indicates you probably ignored my previous posts. We told you what the code was for and explained it in detail. Rob/Shoebox has also answered this question previously. People are going to give up trying to help if you don't go about it the right way.... IMHO.
Old Jul 27, 2003 | 01:14 AM
i am sorry i am new to the board I am just very frustrated and king of pissed off I mean why would GM make such a crappy design? putting a moisture sensitive dist under a water pump???? anyway I have one other question could the harness be bad by any chance?
Old Jul 27, 2003 | 07:48 AM
I think it was already pointed out to check the wiring. You can unplug it and use an ohmmeter to look at it from end to end.
johnsocal
Aug 29, 2002 10:01 AM
MJ_Z28
Aug 7, 2002 07:15 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
