urethane tranny mount?
Old Feb 10, 2004 | 11:27 PM
ram air camaro's Avatar
i put it on today! and i struggled to do it i had to move the tranny a little to the side which i think is now vibrating at 4k rpm pretty bad i also installed a new crossmember.
Old Feb 10, 2004 | 11:40 PM
JKDZ28's Avatar
mine vibrates bad too
Old Feb 10, 2004 | 11:47 PM
442olds's Avatar
are you still running the original steel driveshaft. If so yank it out and have it aligned and balanced by a professional driveshaft place. the factory steel shafts are welded incorrectly and will be out of blanace at higher rpms. They had to replace the whole tube on mine, cost about $150. That or try and get an aluminum driveshaft from a newer car.
Old Feb 10, 2004 | 11:49 PM
did you have trouble putting it on? i had to shift the transmission about a half inch or so to get the bolts to go in is that normal?
Old Feb 10, 2004 | 11:54 PM
hey (442olds) kind of makes sense to me, is that only because its a poly urethane mount because with the regulur rubber one didnt have trouble putting?
Old Feb 10, 2004 | 11:55 PM
Kryckter's Avatar
I also have a 4k vibration but thought it was due to some bad plugs or wires. I may try swapping my urethane mount out for a 1lE mount. I heard those were stron but not as rough on the vibes!
Old Feb 11, 2004 | 09:51 PM
TTT
Collinjacobfowl
Jul 30, 2015 09:35 PM
wesley81
Jul 27, 2015 11:31 AM
Jul 10, 2015 02:23 PM
Noer
Parts Wanted
Jul 4, 2015 05:13 PM
