Update - Race Prep 383, Vette Doctors DFI tuning
Old May 2, 2004 | 08:11 AM
  #16
jimbjr's Avatar
I'm going to have to look for my receipt for the DFI.
I purchased it with the LT1 harness and the nitrous harness.
The install wasn't cheap either.
Jim
Old May 2, 2004 | 08:32 AM
  #17
ChevyIron's Avatar
Thanx Jim I know its not a cheap mod but at my stage I just want the car running right.One more thing who installed the dfi for you?
Old May 2, 2004 | 10:51 AM
  #18
Highlander's Avatar
Originally posted by jimbjr
This winter I might pull the heads and flow them. Just so the curiousity stops.
If the heads are flowing the numbers, couldn't the LT4 manifold be the restriction?
Jim
YES!!!! THE LT4 Manifold is VERY VERY SMALL UNPORTED!!!!! I saw mine and I was totally dissapointed... I suggest before removing the heads, send the manifold to phil @ ai.
Old May 2, 2004 | 11:47 AM
  #19
jimbjr's Avatar
ChevyIron,
The Vette Doctors did the install and tuning. They're installing one on a low 9, high 8 second vette right now. Does the 97 Camaro have OBD II, you should give them a shot tuning it before the dfi.
Highlander,
What exactly is done to the manifold? Can the same thing be done to an LT1 manifold (I have an extra)..
Jim
Old May 2, 2004 | 11:48 AM
  #20
Highlander's Avatar
If you have lt4 heads the lt1 wont fit correctly w/o spacers and such...
goto
advancedinduction.com
There are pics there of the porting.
Old May 5, 2004 | 08:00 AM
  #21
IllusionalTA's Avatar
Gen VII is typically 1500 w/o WB02 for the LTx harness included.. W/ wb02 its 2300-2500 depending on where you get it.. The actual install is quite straight forward the stock pcm harness unplug's just inside the passenger side fenderwell.. Its a lil bit in depth but if you have time you can do it yourself. You can keep your speedo if you keep the stock pcm and just splice it somehow.. www.fasttrackperformance.com i believe they are pretty good w/ these system's..
DirtyDaveW
Mar 15, 2015 07:01 PM
IgorT.455/406
Mar 12, 2015 03:39 AM
MadMav
Feb 6, 2015 11:02 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
