Unwanted affect of degreeing an LT1 Cam
Old Jun 17, 2008 | 04:08 PM
  #16
DirtyDaveW's Avatar
I wish I still had that. I put on the LTCC(original one) back in 2003. The LTCC setup has you ditch the stock coil and ICM so I don't even have that.
Originally Posted by ulakovic22
That's what I would do. Put the stock ignition back on and see what happens.
Old Jun 17, 2008 | 04:12 PM
  #17
DirtyDaveW's Avatar
The Opti is still used for signaling, yes.
I don't know what it is just yet. I just know what it isn't. I'm leaving work now to go get a timing light, index the Harmonic Balancer and see where the spark is going per cylinder. Stay tuned for updates. Lol
Originally Posted by SS RRR
What about the LTCC box? The lobes would have to be extremely out of whack for the cylinders not to fire. You could always put the stock ignition back on and see what happens...
Also isn't the LTCC still opti dependent for cam position? Wondering if that may have something to do with it.
Old Jun 17, 2008 | 04:35 PM
  #18
blown383's Avatar
Also check your valve adjustment..... the rockers might be too tight or you may have bent pushrods.
-B
Old Jun 17, 2008 | 05:07 PM
  #19
DirtyDaveW's Avatar
That was one of the early things I checked on. They were all spot on. Thanks though..
-B
Old Jun 17, 2008 | 05:21 PM
  #20
gatorhead's Avatar
It was already hit on but the opti is still what determines when and where the spark goes. The Ltcc uses the signal from there to produce the spark, if it is not getting the signal on those two then no spark.
Old Jun 17, 2008 | 06:26 PM
  #21
DirtyDaveW's Avatar
Looks like I may have isolated it. TurboBobs LTCC has a couple of LED's inside the housing for the processor. I'd PM'd Bob last night asking if he had any idea if the LTCC could play a role in this. He asked me to pull off the cover of the box and look at the LED's.
Upon "KEY ON", they go thru a bulb test and flash once. Then, when you crank, the green LEN *should* illuminate and stay on. Mine does. The red LED is for diagnostics. Here's what the .pdf file just told me....
Red LED flashes once = Cylinder Decode sequence error.
Red LED flashes twice = Wrong number of Hi Res Pulses counted between Lo-Res Rising edges.
Red LED flashes Three times = Wrong number of Hi Res Pulses counted during a High Lo-Res pulse or a Low Lo-Res Pulse.
Red LED flashes four times = EST (Electronic Spark Control) signal from PCM = missed pulse. Check connection to white wire.
Mine is flashing 3 times.
I've sent a PM to TurboBob to see if this means its wiring or time for a new OPTI.
Old Jun 17, 2008 | 07:40 PM
  #22
87Aerocoupe's Avatar
I think you need a new opti but Bob will tell you for sure.
Old Jun 19, 2008 | 11:47 PM
  #23
DirtyDaveW's Avatar
Well.... over nighted the Opti and a new Opti Pigtail and it was here to great me when I came home from work. Tested them before installing it by just hooking up the harness to the new one, turned on the key, spun the opti. The red blinking light on the LTCC was gone and I could hear the spark plugs sparking. Cool ... So I installed it. Then swapped the injectors back to the mototrons. Reflashed the PCM with Bryans tune and fired it up.
IT RUNS THE SAME G*D DAMNED WAY AS IT HAD!!!! Running on 6 cylinders at the most.
UNbelievable! This is so sad it's funny.
I tried relashing it with the timing advanced 2 degrees across the board since it starts so weakly. Doesn't matter.
Ill get a timing light tomorrow and see it that reveals anything.
The scanner says it's got 32 degrees at 850 rpm now. It did say 30 before I added the extra timing.
Old Jun 20, 2008 | 08:54 AM
  #24
ulakovic22's Avatar
So you have fuel in those cylinders and you have spark as well, but it doesn't fire off the cylinder? What's the temp for those header tubes?
Old Jun 20, 2008 | 09:12 AM
  #25
Kevin Blown 95 TA's Avatar
Here's a good idea - get an infrared thermometer on those tubes and see if they are cool. I also suspect ignition. It's unlikely its a cam thing, and doubt it's fuel related.
Old Jun 20, 2008 | 12:12 PM
  #26
SS RRR's Avatar
Not sure if you've checked this, but are you sure the injectors you've replaced on the two problem cylinders are actuating?
Old Jun 20, 2008 | 01:10 PM
  #27
DirtyDaveW's Avatar
Everything in the ignition(Opti(New), coils, pigtails(New), plug wires(New), plugs(2 sets)) has been replaced.
The fuel injectors have been swapped with another set.
Valve lash verifiend(it was fine before)
Compression test verified (125 psi on each cylinder)
There are no headers. This is a turbo manifold log style.
Spark verified on each plug for it's wire and it's coil(I'm using the LTCC/LS1 coil setup)
Plugs are wet with fuel/fouling after 4 minutes of running. If this keeps up, it'll wash the rings out.
Old Jun 20, 2008 | 01:21 PM
  #28
ZL1modified's Avatar
Doesn't the opti send signal to the pcm first and then to your ignition source? I could sware that it does and if that is the case then your pcm might be the blame...
Old Jun 20, 2008 | 01:40 PM
  #29
DirtyDaveW's Avatar
I'll have to check that. Thanks
Old Jun 28, 2008 | 09:53 AM
  #30
DirtyDaveW's Avatar
Found my cam specs. Going to pick up the cam degree kit plus the nut you put on the crank to turn it over. I have to wait till about noon today to meet the guy (Fbody Buddy of course! The best guys/girls on the planet!) to pick up his kit, accessories. I did a little more research (prompted by fellow LS1Tech'r Chuck Norton. Thanks Chuck!) and found that not only did my engine builder not adv/retard the cam 2 degrees as he'd stated, the timing set (CLO-9-3145) doesn't even have a provision for just 2 degrees. It has 3 keyways. 4 degrees Advanced, "Standard/Dot-to-Dot" and 4 degrees Retarded. (For those in Rio Linda, that means you can't *just* add/subtract 2 degrees with this timing set). Something stinks here (and it's not just that shirt I've been wearing while under the car) Using the ICL (Intake CenterLine method) the cam should show a 112 ICL if it's degreed properly.
