Ugh, problem still not fixed!
Old May 19, 2004 | 03:17 PM
AlexBarabas's Avatar
I thought I fixed it by switching the fuel filter... drove it around and seemed to be working well, but now I get the same problem back. It "hiccups" when I press the gas and it's at low rpm... no rpm drop though... also, if i just let the car idle around at 1000 rpm in any gear, it sounds like something's rattling around in the tranny -- I think I was hearing this before I got this problem though.
Could there be anything wrong with the transmission at 58K miles... or the clutch? It's got a Spec clutch that was put in about 40k miles ago. What about an injector or fouled plug?
Any advice on this?
Old May 19, 2004 | 03:19 PM
Ryan's LT1's Avatar
Rattle?
Check your cat. Mine rattled and was causing a bit of a stumble and power loss too.
Old May 19, 2004 | 03:22 PM
Not a rattle... the whole car "hiccups"... it feels like a stall or turning off a diesel engine... or "bogging it out" when you're letting the clutch slip too much and not adding enough gas.
Old May 19, 2004 | 03:35 PM
If I cant fix this myself or have it fixed really cheap, screw it... I'm going to just get a new car off the showroom floor and suck it up paying it off over the next few years.
Old May 19, 2004 | 05:10 PM
ttt
Old May 19, 2004 | 05:14 PM
DonHood's Avatar
I'm tellin' ya man, it's probably a plug wire that's arcing.
Old May 19, 2004 | 05:15 PM
Plug wire that's arcing? How do I go by fixing/repairing this? Just replace the plug wires?
Old May 19, 2004 | 05:17 PM
96ss2nv's Avatar
Possibly your Opti going out. That's how mine acted when it was dying. As for the rattle, try pushing in the clutch. If the noise goes away, then it's the throwout bearing. My M6 has always had a loud TO bearing.
Old May 19, 2004 | 05:26 PM
DonHood's Avatar
You can check them for signs of arcing when it's really dark. Start it up and look under your hood. An arcing wire will flash anywhere it's touching something that'll ground it out.
Old May 19, 2004 | 05:30 PM
Yea, I think the other noise is the T/O bearing... I remember noticing it about a year ago.
I think it's time to change the spark plugs and wires too anyway -- been noticing slightly longer ignition times. What do you guys suggest I replace the optispark with -- and the wires/plugs? Would I have any sort of advantage going for a hotter plug?
I wish these things would just run on magnetos!
Old May 19, 2004 | 05:50 PM
Ah, another thing that I should have mentioned -- none of this "bogging out" or "hiccuping" happens when it's in neutral and I rev it. Could it still be the opticrap?
Old May 19, 2004 | 06:20 PM
DonHood's Avatar
Ohhhh, it's taking longer to crank now? That's a sign of a bad fuel pump, or opti. Neither one of them are very fun. I'm leaning more towards your opti being shot now.
AlaskaZ28
Apr 17, 2015 08:54 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
warmeck
Mar 22, 2015 06:43 PM
mattstrike
Mar 11, 2015 07:33 PM
MislMan
Jul 19, 2002 11:41 AM
