Ugh, problem still not fixed!
I thought I fixed it by switching the fuel filter... drove it around and seemed to be working well, but now I get the same problem back. It "hiccups" when I press the gas and it's at low rpm... no rpm drop though... also, if i just let the car idle around at 1000 rpm in any gear, it sounds like something's rattling around in the tranny -- I think I was hearing this before I got this problem though.
Could there be anything wrong with the transmission at 58K miles... or the clutch? It's got a Spec clutch that was put in about 40k miles ago. What about an injector or fouled plug?
Any advice on this?
Any advice on this?
Not a rattle... the whole car "hiccups"... it feels like a stall or turning off a diesel engine... or "bogging it out" when you're letting the clutch slip too much and not adding enough gas.
If I cant fix this myself or have it fixed really cheap, screw it... I'm going to just get a new car off the showroom floor and suck it up paying it off over the next few years.
Possibly your Opti going out. That's how mine acted when it was dying. As for the rattle, try pushing in the clutch. If the noise goes away, then it's the throwout bearing. My M6 has always had a loud TO bearing.
Originally posted by AlexBarabas
Plug wire that's arcing? How do I go by fixing/repairing this? Just replace the plug wires?
Yea, I think the other noise is the T/O bearing... I remember noticing it about a year ago.
I think it's time to change the spark plugs and wires too anyway -- been noticing slightly longer ignition times. What do you guys suggest I replace the optispark with -- and the wires/plugs? Would I have any sort of advantage going for a hotter plug?
I wish these things would just run on magnetos!
Magenta_Hearts
Mar 25, 2015 10:24 AM
I'm leaning more towards your opti being shot now.
