Two peice main seal crank and LT1
Old Aug 26, 2003 | 08:29 PM
Highlander's Avatar
I have a lunati crank installed on an LT1 corvette and I was having problems with the flywheel and the starter... The flywheel is a bit bigger than the lt1 crank and thus the starter doesn't line up...
I was supposed to have a one peice rear main seal but, the guy I bought it from gave me a kit to install it on the LT1...
Any suggestions?? are there any special flywheels I can get? OR I just have to use a spacer or something???
Old Aug 29, 2003 | 12:06 PM
Highlander's Avatar
I think I will measure up the distance I need and make a plate for the starter with an aluminum plate I got.. any other suggestions??
Old Aug 29, 2003 | 12:53 PM
Compstall's Avatar
If there's too much gap between the starter and flywheel teeth, you can fab up a spacer and get it to fit correctly. If the fit is too close, you can have the mating surface on the starter milled down.
Old Aug 29, 2003 | 01:05 PM
Highlander's Avatar
That is what I am doing.. I wanted to know if there is any special flywheel for this kind of situation, since there was a kit (the one I used) to install it on the lt1
Old Aug 29, 2003 | 03:03 PM
Ai's Avatar
Ai
Your flywheel bolt circle diameter matches the bolt circle diamter of your 2pc seal crank? I ask b/c older 2pc cranks are 3.57 or 3.58" IIRC, and new stuff is right at 3". Even if it is, you may have clutch issues I believe b/c of the flywheel thickness or relative heights of the PP mounting surface & friction surface.. if that makes sense .
You'll likely just need a new flywheel meant to adapt 2pc cranks to late model trans/clutch setups & both Centerforce and Fidanza make them I believe .
http://www.aluminumflywheels.com/ is Fidanza's site & the p# you're looking for is 198661 I believe.
Old Aug 29, 2003 | 10:25 PM
Highlander's Avatar
This is an auto...
I am using a flywheel for the 2pc cranks.. because the other one didn't line up with the bolts...
This one has a total diameter that is larger than the lt1 has.
Old Aug 29, 2003 | 10:33 PM
Ai's Avatar
Ai
LOL
You said flywheel instead of flexplate so I was thinkin' manual
Old Aug 29, 2003 | 10:36 PM
Highlander's Avatar
OIC... I thought it was the same... IN spanish its the same name...
Anyways... That plate is just to crank the car... I believe.
Old Aug 29, 2003 | 10:42 PM
EviLZ28's Avatar
PART#471529 is a 153 tooth 12 3/4 diameter flexplate for a 2 piece rear main seal. The stock diameter flexplate is 153 tooth 12 3/4 diameter on the LT1's. If you have the larger 168 tooth 14" diameter, you are gonna need a different starter.
EDIT' I should have asked. Since you put a new crank in your motor, did you have it balanced? If you did, did they balamce it to the bigger flexplate?
Old Aug 29, 2003 | 10:59 PM
Highlander's Avatar
Which starter? got any part number? and from where is the part number you supplied?
Old Aug 29, 2003 | 11:24 PM
EviLZ28's Avatar
Well if your gonna go the starter route, I would buy a mini torque starter. The correct starter for the 168 tooth flywheel is larger and might cause some clearance problems. A mini torque has both bolt patterns for the small and large flywheels. I have seen guys selling brand new ones on ebay for 89.00 bucks. Or you can get these from summit as well.
The part number I gave you is a gm flywheel. I got the part number form one of my GM high po catalogs.
HectorM52
Jul 30, 2017 11:46 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
1LEThumper
Jul 14, 2003 12:45 PM
AutoRoc
Aug 7, 2002 11:45 PM
BIGCOWL-IMP
Jul 22, 2002 04:28 PM
