Turbo build OR heads/cam/150 shot?
Old Dec 28, 2008 | 09:40 AM
  #31
96capricemgr's Avatar
Met a guy running a turbo 11psi and alky on a forged piston but otherwise stock Impala LT1, ran 12.8 in October at the time I was impressed, these days my NA times in the worst weather the midwest can throw at it are about that, but then I bought good parts so your results may vary.
Old Dec 28, 2008 | 10:26 AM
  #32
RealQuick's Avatar
1982z28with18s ran one of my log manifold kits on a mild LT1. Here is his setup:
(8lbs in 1st, 11.5 in 2nd and 3rd, lifting 1-2 shift and tranny wouldnt shift correctly - 91/110 Octane w/ 24 degrees timing) - 10.8 @ 127.8mph w/1.56 60'
355ci 9.5:1 CR
LT1 Boost Log Manifold kit with BB T76 Q trim and 44mm wastegate
Stock Heads
Stock Cam/intake/TB
TH400 w/ 4000 stall and 3.42 gears/10 bolt
Stock ECU
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
Slayer
Jul 4, 2015 03:06 PM
dylan1303
May 22, 2015 12:24 PM
Potent77
Apr 1, 2015 12:45 AM
