Tuning for cc306 & 385 LT1
Old Dec 5, 2004 | 10:39 AM
BlueCamaroZ28's Avatar
I just started my rebuilt 385LT1 with cc306 camshaft and the following mods:
52mm BBK TB
30# FMS injectors
Stock Fuel Pump
Long Tube headers
Ported LT1 heads
Ported MAF
Eagle forged rotating assembly with -16 dish pistons.
Manual Transmission/3.54 rear ratio
I still have my old tune for ZZ9 cam and flat top pistons (11:1 CR).
What exactly need to be changed in the the new tune. Will it make a big difference.
Also, my check engine light is on and the fan is on all the time. I used EZ link to scan for error codes but found no errors.
Any help.
Old Dec 5, 2004 | 12:38 PM
ejfagala's Avatar
Re: Tuning for cc306 & 385 LT1
Get a hold of Ion, he did my initail tune and i have a very similar set up to yours. With his bin file my car started and idled great right out the box and had Zero cam surge. Since you have a new motor it is definatly worth the $60-$80 (depending if you have a tuner program and can use e-mail).
Old Dec 5, 2004 | 12:41 PM
SS MPSTR's Avatar
Who tuned your previous set-up?
Old Dec 5, 2004 | 04:15 PM
amean94ta's Avatar
get a mail tune to get it running then get it to a dyno tuner ion did ok but you cant beat a dyno tune on a motor like yours btw i have a 13.6:1 compression 396 and the tune made it run but it really needed the dyno tune to get it perfect
Old Dec 5, 2004 | 09:59 PM
ejfagala's Avatar
I agree it needs to go to the dyno for final tuning (I picked up 31 HP) but definatly get the mail order form Ion to get the thing up and running without washing the rings out or somthing else bad.
Old Dec 5, 2004 | 10:21 PM
Thunder Racing did the PCM tuning.
DirtyDaveW
Dec 1, 2016 05:37 PM
Red_94Formula
Jan 22, 2015 12:17 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Nostang 96z
Aug 31, 2002 12:01 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
