tune-up
Old Mar 19, 2004 | 08:37 PM
jayman117's Avatar
tune-up
I'm doing a full tune-up on my Z(plugs wires, opti ect..). The guy at the shop told me that i'm better off going with all GM parts so that I don't run into trouble. Is this the best thing to do? or are there better choices out there?
Old Mar 19, 2004 | 08:41 PM
hawk232's Avatar
i would agree with all of that except wires, i use msd wires
Old Mar 19, 2004 | 08:42 PM
ArizonaZ's Avatar
Using GM parts is just a way to spend more money. There are definately better choices for the money/"performance".
Old Mar 19, 2004 | 09:23 PM
Robs97Z28's Avatar
most of the guys I've seen on here are running NGK tr55 and Taylor wires..
Old Mar 19, 2004 | 10:23 PM
OBE1 95Z28's Avatar
Are you having trouble with your opti? I don't consider it a tune-up part...how many miles on your car? I'm not a big fan of the MSD wires; I've had the boots crack (not heat damage) and they certainly won't fit in the stock looms (8.5mm). I personnally like the Accel 9000 wires (8mm) and cheaper that GM wires. As for plugs I'd recommend the stock AC Delco platinum for your mods. They'll give you long life (platinum).
Old Mar 20, 2004 | 12:54 AM
jayman117's Avatar
I have about 72k on it right now. I was getting a stumble at low rpm and a hesitation up high, i was told that my opti was soaked in oil from a leak in the crank seal.
Old Mar 20, 2004 | 11:05 PM
Dan K's Avatar
I just did the same thing last saturday. New opti, waterpump, plugs, and wires. Took about 10 hours total including getting the wires in the factory looms and such. Not fun.
jmadoll
Jun 29, 2015 11:21 PM
NOTIME383
Jun 17, 2005 10:30 PM
84zed
Feb 23, 2005 09:39 PM
mako350Z28
3rd Gen / L98 Engine Tech
Apr 6, 2004 04:01 AM
SFB767
Jul 8, 2003 08:57 PM
