Off hand, what tools needed to change calipers..
Old Mar 20, 2004 | 02:45 PM
chesee48's Avatar
I've had new Slotted rotors sitting in my garage for a long time and i was thinking about throwin them in soon...
Just wanted to know what exact tools were needed off hand so i can decide if i want to do it tonight or wait till i get back from Cancun
Old Mar 20, 2004 | 08:06 PM
$hawn's Avatar
Front or back? I'll assume the front. At least something to take the wheel nuts off, 3/8 allen socket, c clamp to compress the caliper piston, those are the main ones anyways.
Old Mar 20, 2004 | 08:28 PM
chesee48's Avatar
both. front and rear
Old Mar 20, 2004 | 09:56 PM
95_LT1_6SPD's Avatar
some sockets and a set of channel locks to compress the pistons should do the trick.
Old Mar 20, 2004 | 11:36 PM
ishz28's Avatar
If it's been awhile since changing the pads or rotors. You might need a hammer to use with the Allen wrench to tap the bolts loose and then to tap around the rotor inner surfaces (or anywhere on the rotor if replacing) to break it free form the hub.
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
FASTFATBOY
Jul 6, 2002 01:02 AM
