Try to lift the engine out. Please help.
Old Aug 1, 2004 | 03:30 PM
desertfox's Avatar
Hi Guys.
I'am going to lift my engine out from my 94 Z28. I don't have a shop car lift, so I only can lift my car up about 18-20" high from the floor. So in this case not so easy to remove the m6 transmission alone. My question is, is it possible to lift the engine out from the body with the transmission on? Or any easier way? I do alone and my wife, but she only give me the tools, when I'am under the car, so she can't help much.
Thank you.
Old Aug 1, 2004 | 03:40 PM
Re: Try to lift the engine out. Please help.
I took my engine and trans (together) out the bottom, by myself. The bottom of the front of the car needs about 36" height.
Old Aug 1, 2004 | 04:33 PM
klbjoc's Avatar
What did you do with the car after you pulled the engine and trans? Did you leave it in the driveway?
Old Aug 1, 2004 | 04:53 PM
Yeah, I didn't need to go anywhere.
Old Aug 1, 2004 | 05:14 PM
dreamer1q's Avatar
you can try my way as well
http://www.michiganspeed.com/enginepull/index.html
Old Aug 1, 2004 | 05:54 PM
TheCap10's Avatar
OMG, the cat's expression says it all. (right in front of the body)
Old Aug 1, 2004 | 06:17 PM
Dave88LX's Avatar
I came out the top as well.
If you can only go 18-20", you may have some 3-ton jack stands...you can get a set of 6-ton jack stands that will go up to 23-24" high, might want to get those...
Anyways, this is pretty much how I did it (I forget the exact order, it's been too long, just go whichever way makes sense)
Drop Trans
Remove all accessories on top of engine
remove intake
remove front accessories
remove wiring harness from pcm and firewall, or unhooko completely from engine (I went the 2nd way)
Remove Fans & radiator
Get a chain going from the back to the front, and hook the engine towards the front. I lifted the engine up, slid it forward, then spun it 90* sideways to lift it out if I remember right. Do a search on me from a while back on a spun bearing...should be a lot more info there.
Here's my directory of pics if they might help:
http://paradox.shacknet.nu/dave88lx/formula/knock/
Engine coming out:
http://paradox.shacknet.nu/dave88lx/...nock/pull2.jpg
Old Aug 1, 2004 | 08:44 PM
desertfox's Avatar
Thanx so much guys. I try on the next weekend, because now I'am to tired. I will give a post how I did.
So thanx again.
Old Aug 1, 2004 | 09:16 PM
Dave88LX's Avatar
If it's any consolation, I did it entirely myself as well...shoebox can vouch for me, he was watching on webcam
Old Aug 1, 2004 | 09:56 PM
Guilty as charged.
rideordie
Nov 5, 2019 04:52 PM
Roadie
Feb 16, 2015 10:34 AM
edman
Jan 25, 2015 02:41 PM
kandied91z
Jan 23, 2015 11:14 AM
1775.Z28
Jan 11, 2015 10:51 AM
