The Truth about HP and TQ (proven w/ physics)
Old Mar 17, 2005 | 04:27 PM
  #16
SStrokerAce's Avatar
Re: The Truth about HP and TQ (proven w/ physics)
Guys go look up the Advanced Tech thread that OldSStroker and Racer got into this a LONG time ago.... Otherwise you guys are missing out on something that beat a hole heard of horses to death.
In reality it's the TQ at the tires that counts the most.
I like to look at TQ at HP peak per cube (or L) that tells you a lot more about a motor.
Bret
Old Mar 17, 2005 | 04:30 PM
  #17
1racerdude's Avatar
TQ gets it moving---- HP takes it out the back door....
Old Mar 17, 2005 | 04:37 PM
  #18
disco192's Avatar
Im pretty sure its nailed down in my head. If it didnt come across, then maybe I needed to elaborate more. I am a Jr in Aerospace Engineering at the University of Texas, so Ive been around the block when it comes to physics and statics/dynamics and all the calculus.
I realize that it is a dynamic condition where there are multiple variables to determine acceleration (i was ignoring traction, rolling resistance, wind resistance, and moment of inertia of the rolling masses). I beleive that the (HP/Speed) x Constant = Acceleration is an accurate formula and can be even used with HP as an appriximated function of RPM.
Originally Posted by OldSStroker
Here we go agian.
It's about time for this again, isn't it? Yes, it's a good topic to discuss. You may get a few (?) differing opinions. disco192, you are on the right track, but that you "fully understand it" might be an very slight exaggeration.
FWIW: Yes, F=ma applies. That's going to be the difficult part to remember as this thread goes where most have gone in the past. The "F" is the (thrust) force applied to the chassis by the drive tires. This is an opposite reaction to the force at the tire/road contact patch, which depends on the axle torque and rolling radius of the drive tires, as well as load and tire fricton coefficient, sometimes referred to as "bite" or simply "traction".
This much is intuitive to many, but not all, folks. However, this is just an instantaneous or "static" look at it. As soon as the vehicle moves, we have a "dynamic" condition, so we need to look at the rate at which the torque is applied. Here is where "power" comes into play, and where this type of thread usually diverges.
My $.02.
Let the games begin...
Old Mar 17, 2005 | 07:55 PM
  #19
Jon A's Avatar
It is. It works right with Power = Force X Velocity which becomes Force = Power / Velocity. Then the Force gets plugged into Acceleration = Force / Mass to give you your acceleration for a given power level, speed and mass. You should have no problem deriving all that absolutely to give you some actual numbers to chew on (then you can start adding in rolling resistance, aero drag, etc).
Definately check out the thread Bret mentioned.
Old Mar 17, 2005 | 08:00 PM
  #20
CANTONRACER's Avatar
Torque
Hmmm...think what that bad boy would do in a 3200 lb Fox body with a 3.08 gear?
Old Mar 17, 2005 | 08:43 PM
  #21
1quikZ's Avatar
pffffffff ford, i dont care how much trq or Hp those things make to me none of them have any *****..........lol
Old Mar 23, 2005 | 11:49 AM
  #22
respectirocz's Avatar
torque is multiplied through the gear ratios and final drive of all cars
the dyno measures the torque at the wheels which may be around 1250 or so
but the tire is not moving 5000 rpms
so the equation still applies
hp = tq*rpm/5252
u get a huge amount of torque but the same horsepower
the way i see it, the dyno reads the torque at the wheels
then reads the wheels speed to determine horsepower
which then uses engine rpm to find gross engine hp
Old Mar 23, 2005 | 01:31 PM
  #23
ChevyTuffD.A.'s Avatar
So if u had 300 horsepower, does that mean it would be like 300 horses pulling your car??
Aug 17, 2015 09:50 AM
MDZ28
Exhaust System
Jun 2, 2015 09:48 PM
R@mpage
Apr 20, 2015 10:02 AM
FredM
Exhaust System
Feb 18, 2015 05:37 AM
redzed
20
Nov 5, 2002 06:24 PM
