HELP!!! car wont start
Old Mar 22, 2005 | 09:26 PM
hallbilly's Avatar
allright i go to get in my car, and put the key in and turn it forward and no lights come on... the head lights are good, radio is good... battery seems to be 100%... but when you turn the key forward no lights or anything come on... i have no clue what it could be also.. it will not turn backwards all the way... for the radio or what not... so maby it could be the ignition switch or assembly? help me out guys i dont want to be stuck at work all night!
1994 z28 Auto... stock 83k miles
Old Mar 22, 2005 | 09:31 PM
roguedriver's Avatar
Re: HELP!!! car wont start
Sounds like you might have diagnosed your own problem. That being the ignition switch. Especially since it doesn't seem to be working right.
Old Mar 22, 2005 | 09:33 PM
hallbilly's Avatar
im hoping so.. how much would one cost from like autozone?
Old Mar 22, 2005 | 11:24 PM
hallbilly's Avatar
anyone else have idea?
Old Mar 23, 2005 | 01:21 AM
hallbilly's Avatar
guess i will start checking wires tomorrow... if a ground or something was unhooked would it act this way? It ran perfect before i parked it... ran about all day long. I had my old codes pulled earlier today... These were codes that had shown up in the past... no current ones were flashing... 32-egr failure, 36-hi-res failure, 73-force motor current, 90-torque clutch error
i don't know what those are... doubt they would be they reason since it ran and started several times after the code check
Old Mar 23, 2005 | 01:48 AM
fredmr39's Avatar
I'd figure out what is going on with the ignition switch before anything - since that seems like the easiest to address. Sorry I'm not much more help than that - but hang in there...you'll get answers tomorrow when people are checking the site.
Old Mar 23, 2005 | 11:18 AM
hallbilly's Avatar
allright, i jumped over the starter and it will not engage the flywheel thing (automatic) would that be part of the reason for not working!?!?!
Old Mar 23, 2005 | 01:55 PM
m0nk's Avatar
If you turn your key to the "run" position and your dash lights do not light up, but your radio still works, it is usually a sign of a bad ignition switch, the electrical part. Its above your steering column and usualy costs around 20-30$ if I remember correctly
Noenav
Mar 1, 2019 07:38 AM
97SSdude
Dec 31, 2014 07:43 PM
tds1213
Nov 27, 2014 12:55 PM
USAirman93
Nov 24, 2014 03:37 PM
Dave19yz28
Jan 26, 2003 01:45 PM
