Trouble code help
Old Apr 6, 2006 | 05:48 PM
Wicked 97TA's Avatar
Trouble code help
I went and got my car checked with a scan tool today and these are the codes I got:
P0171- Sytem too lean, left bank on 4 sensor systems
P0174- System too lean, right bank
I know it could possibly be the MAF sensor, MAP sensor, or the O2 sensors.
Can anyone help me out here?
Old Apr 6, 2006 | 05:59 PM
blitzer454's Avatar
Re: Trouble code help
or it could be a vacuum leak somewhere. Check your vacuum hoses and make sure the intake elbow is on correct. Also check the hose to the air pump.
Old Apr 6, 2006 | 06:19 PM
Leaks in the exhaust before the O2 sensors and misfires can cause a "false" lean condition. Low fuel pressure, faulty MAF, large vacuum leaks, a hole in the inlet bellows will all cause a lean condition.
Old Apr 6, 2006 | 07:28 PM
JP94Z's Avatar
Try to get ahold of a fuel pressure gauge, make sure it's getting enough fuel first. Best to find out if it's false or not, just in case it really is lean.
Old Apr 6, 2006 | 07:35 PM
I have a problem with a whistling, kinda screaming sound that occurs when you start the car and quites down as the car reaches running temp. Can these two things be related?
Old Apr 6, 2006 | 09:14 PM
moparman's Avatar
That sound could be a vacuum leak. Raise the hood and see if you can pinpoint where it's coming from.
Cam's maro
Mar 24, 2015 08:09 PM
armedtrigger
Feb 24, 2015 08:30 PM
David Dorris
Jan 17, 2015 08:10 PM
91Bird305
Aug 5, 2002 01:39 PM
LT1
Jul 2, 2002 08:27 PM
