Trouble Code Help
Old Sep 2, 2004 | 10:12 PM
klpps's Avatar
Trouble Code Help
P0161 - something to do w/ bank 2 sensor 2 voltage. I did some searches on the board and got some info but still had a couple questions.
I'm a newb and was wondering which sensor was having the problem. Also, what causes this trouble code and does it require me getting a new o2 sensor. any help would be appreciated.
Old Sep 2, 2004 | 10:42 PM
Re: Trouble Code Help
P0161 Heated Oxygen Sensor (HO2S) heater circuit Bank 2 Sensor 2
It's the post cat sensor on the passenger side. It does not affect performance. The sensor is just there to check on the performance of the cat. Could be a wiring/connection issue or the sensor, itself.
Old Sep 2, 2004 | 10:52 PM
klpps's Avatar
should i replace the o2 or not worry about it and just turn the light off whenever it pops up?
Old Oct 26, 2004 | 07:11 PM
klpps's Avatar
ttt
Old Nov 19, 2004 | 11:43 PM
klpps's Avatar
could this code be due to a bad cat?
Old Nov 20, 2004 | 02:27 AM
Dave89IROC's Avatar
this code? very unlikely
a bad cat would get a catalyst efficiancy failure code, not an o2 sensor circuit code
Old Nov 20, 2004 | 10:17 AM
klpps's Avatar
so you recommend I just replace the sensor then?
Old Nov 20, 2004 | 01:05 PM
Dave89IROC's Avatar
the odds are that it is the sensor, check the sensor and all the fuses first, if all that looks good, replace the sensor
Old Nov 20, 2004 | 01:15 PM
Could be the heater in the sensor, or could be the power supply to the sensor heater. Easy way to check is to swap the post-cat sensors side-to-side. If the problem follows the sensor, its a sensor probelm. If the problem stays on the passenger side, its the wiring or the power source.
Cam's maro
Mar 24, 2015 08:09 PM
armedtrigger
Feb 24, 2015 08:30 PM
David Dorris
Jan 17, 2015 08:10 PM
91Bird305
Aug 5, 2002 01:39 PM
LT1
Jul 2, 2002 08:27 PM
