Trouble Code Diagnosis/Service Manual Related Question
Old Jan 24, 2007 | 08:29 PM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
In the factory service manuals, when conducting diagnosis of an On Board Diagnostic trouble code and it says to check for a voltage reading of B +, what does that mean? Does it mean a positive reading equivalent to whatever voltage the battery is putting out? I'm sure there is probably a key somewhere in these books that would tell me exactly what it means, but I've yet to find it and these books are huge. I thought maybe someone here might know.
I've conducted a couple of tests and the reading I'm getting is 12 volts, but I'm not sure whether that represents a True or False condition when the test is for a reading of B +.
If this isn't the correct forum, I apologize.
Old Jan 24, 2007 | 10:19 PM
Originally Posted by BTC
..... Does it mean a positive reading equivalent to whatever voltage the battery is putting out? ......
Yes.
Old Jan 24, 2007 | 11:50 PM
BTC's Avatar
BTC
Thank you. I was troubleshooting an OBDI code 48. I believe I have a bad MAF sensor.
Old Jan 25, 2007 | 11:44 PM
And you should be looking for +12V on the pink wire in the harness connector.
Old Jan 26, 2007 | 08:20 AM
BTC's Avatar
BTC
There is 12 volts on the pink wire.
DirtyDaveW
Dec 1, 2016 05:37 PM
Gtpguy
Jan 26, 2015 04:50 PM
David Dorris
Jan 17, 2015 08:10 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Jul 4, 2005 05:00 PM
