LT1 Intake manifold Prob.
Old Nov 16, 2006 | 12:19 PM
Alex607's Avatar
Hi, Hows it going, I'm new to the forums and I joined because I figure you guys can help me out, I had my car up on a lift and found out I had an oil leak coming from the back of the intake manifold and oil pressure switch, While I rip the old intake manifold out to reseal etc. I was planning on putting an aftermarket intake manifold on, I cannot seem to find one, if anyone has any information on the best option for an aftermarket intake manifold let me know, I already have done heads/cam/intake/mass airflow sensor/ etc.
Old Nov 16, 2006 | 12:30 PM
KGRESOCK's Avatar
Currently none are available.
Do a search on Edlebrock intakes.....should be out in the next decade.
Old Nov 16, 2006 | 12:53 PM
Alex607's Avatar
Ok
What if mine to be ported, or maybe an lt4 intake manifold?
Old Nov 16, 2006 | 01:08 PM
Unertl42's Avatar
Just have your LT1 manifold ported, the LT4 intake manifold is way too expensive.
Old Nov 16, 2006 | 01:34 PM
mrmint69's Avatar
Check an auction site. They have many that have been ported already. Unless you like doing that stuff yourself.
Old Nov 16, 2006 | 01:39 PM
Javier97Z28's Avatar
Moderator
Do you have headwork or an aftermarket cam done? If the answer is no, don't bother porting your manifold. Fix your leak and call it a day.
Old Nov 16, 2006 | 01:45 PM
Alex607's Avatar
Yes I have both done.
Old Nov 16, 2006 | 02:31 PM
The LT4 intake won't bolt to LT1 heads without machine work, and isn't any different than the LT1 intake, other than the extra metal at the top of the runners to allow it to be ported to match LT4 heads.
Old Nov 16, 2006 | 08:27 PM
Torq_Radio's Avatar
I shadow the above posts...if you want to get performane out of an intake for yourself and your setup...DONT do a LT4 mani and port yours.
markaubuchon
3rd Gen / L98 Engine Tech
Jan 14, 2015 01:48 AM
ModdedNerd
Dec 14, 2014 10:28 AM
Elcojoe
Nov 17, 2014 10:27 PM
Snoman73
Nov 17, 2014 07:22 PM
Jul 4, 2005 05:00 PM
