Trouble with AFR heads/valve cover sealing
Old Sep 13, 2004 | 09:47 AM
BlownF1's Avatar
Got the motor running and seem to have what we suspect is oil up near the top of the motor towards the rear outside of the passenger side head. I don't believe it's an intake leak, but will confirm.
One thing to note is that the heads are AFR's and when we installed the valve covers, the corners interfered. The rim that the gasket sits on is wider in some areas than the rest, so we ended up bending the edges out slightly. I suspect this is the problem, and if so, what can we do? Probably should of had the extra material removed from the heads, too late to do easily now...
Old Sep 13, 2004 | 09:50 AM
rskrause's Avatar
Moderator
Re: Trouble with AFR heads/valve cover sealing
AFR's need shorter bolts for center bolt valve covers. If you use regular length bolts they will bottom out and the valve cover will not seal properly. I just tooke the cutoff wheel to mine and trimmed them a little.
Rich
Old Sep 13, 2004 | 09:57 AM
WS Sick's Avatar
Rich
Exactly, I used the stock covers for a while with about a 1/4 inch shorter bolts and they sealed fine, I'm now using the Moroso centerbolt covers and the bolts they sent with them were too long as well. They will bottom out and not tighten the covers down completly.
Old Sep 13, 2004 | 10:22 AM
BlownF1's Avatar
Hmmm...that's VERY interesting! I'll take a look at that, thanks guys! Gotta love these "bolt-on" heads. After I bolted them on, I simply had to cut, grind, bend, and tweak everything else! LOL!
Old Sep 13, 2004 | 10:27 AM
WS Sick's Avatar
It's all part of the fun.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
pimpss96
Feb 12, 2015 01:28 PM
MadMav
Feb 6, 2015 11:02 PM
