trick flow heads?
Old Oct 21, 2008 | 11:37 PM
sn8ke eatr's Avatar
trick flow heads?
whats the word on these? anyone got flow #'s
i need to drop my compression ration down a solid amount due to ordering the wrong pistons
Old Oct 22, 2008 | 05:28 AM
Trick Flow posts the flow numbers on their website.
Old Oct 22, 2008 | 09:19 AM
slomarao's Avatar
look on AI's website, they have their TFS heads near 300cfm's.
Old Oct 22, 2008 | 09:22 AM
SS MPSTR's Avatar
the Ai TF head would be an excellent choice. Talk to Ron or Phil about what you've done/built and they can certainly help you get your CR back to where it should be.
Old Oct 22, 2008 | 10:12 AM
awdfun's Avatar
I have a set that flow 315cfm @.600 lift
Old Oct 22, 2008 | 11:30 AM
blue 79 Z/28's Avatar
ive noticed you called it compression "ration" in this thread and the other you made, just pointing out its compression RATIO.
Old Oct 22, 2008 | 08:40 PM
SuperbeaSSt's Avatar
I had a similar problem, I bought my pistons assuming the ported heads I had weren't milled, but they were, bringing my compression up to 13.37 or something ridiculous. The TFS heads brought me down to 11.24ish. So if goal is to bring down the compression without putting new pistons, they work pretty well out of the box, my dyno numbers in my sig aren't the best, but I had some demons in there when I got those #s. I'll post updated info when I get the dyno redone.
Old Oct 22, 2008 | 11:49 PM
sn8ke eatr's Avatar
haha i know thanks auto correct ftl
Old Oct 22, 2008 | 11:51 PM
sn8ke eatr's Avatar
thanks if you would do that for me id appreciate it
Old Nov 15, 2008 | 05:29 PM
greatskiiiier's Avatar
some people
BinkZ28
Apr 20, 2015 09:10 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
