Transmission fluid change
Old Aug 20, 2012 | 10:09 PM
javi805's Avatar
i need help on how to change the fluid on the transmission? any tips plz!!!!!
Old Aug 20, 2012 | 10:35 PM
97z28k&N's Avatar
assuming it is an auto, remove trans pan with a container to catch the fluid. remove rectangular filter and seal, replace, and apply a gasket to the pan. NOTE: You may want to get a ball head hammer to tap the bolt holes on the pan to make them flat again to prevent the pan from leaking. Reinstall pan and tighten bolts to 11lb torque. refill transmission to full amount (around 4-5 quarts).
Under-filling will cause the tranny to overheat and overfilling will cause bubbling and will damage the transmission.
Be careful and good luck!
Posted from Camaroz28.com App for Android
Old Aug 20, 2012 | 11:08 PM
javi805's Avatar
Re: Transmission fluid change
nice thank you i will def do that thanks again for the tips!
PCLZ28
Dec 24, 2015 05:19 PM
jmadoll
May 27, 2015 07:13 PM
warmeck
Mar 16, 2015 07:02 AM
jmadoll
Mar 3, 2015 10:16 AM
jackpawt883
Feb 26, 2015 09:04 PM
