Transgo shift kit and TA performance button, is there a difference ?
Old Jan 11, 2004 | 06:33 PM
jaytone's Avatar
My automatic has the performance button and I am thiniking of installing a Transgo Shift Kit, here are my questions
1. Is it worth installing the Transgo and what to expect.
2. Would I continue to use the Performance button with the Transgo
3. Once installed, does anything in the computer have to be changed or reprogrammed.
4. What would be a guess on having a tranny shop install it.
Old Jan 11, 2004 | 09:50 PM
Josh-'04 GTO's Avatar
1. Yes, with stronger and more positive shifts the result.
2. The Performance button is a joke and only affects part-throttle shifts anyway. It had no bonus at WOT vs. cars w/o the button.
3. No.
4. $250-$300.
Old Jan 12, 2004 | 12:14 AM
revtime's Avatar
It will be a worthwhile upgrade, a shift kit is much better way to go.
Trans Go is a good shift kit in my opinion, its what I run in my trannies, never had a problem.
There is one guy on here that hates them and he builds trannies but to date he is the only professional I have talked to that dislikes them.
Go with the shift kit you will be much happier with it.
Old Jan 12, 2004 | 01:18 AM
Unique07's Avatar
[/QUOTE]
Ditto.
If you get a chance, look at a Trans-Go kit - Lots of hwd and upgraded parts and definately more noticeable that the mod; They compliment each other, but the kit alone would make the bigger difference. I have both...and enjoy what they do over OEM.
armedtrigger
Feb 24, 2015 08:30 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
RedLineRev
Jan 23, 2003 03:51 PM
DarkHorse
Aug 1, 2002 04:59 PM
Jake77444
Jul 21, 2002 05:37 PM
