trans & motor didnt tilt when jack was lowered
Old Jun 10, 2013 | 06:49 PM
will.b.brown's Avatar
I figured i would drop my trans and then the bellhousing/clutch. I have everything disconnected. All trans bolts are out except the top two, the cross member is out and yes the driveshaft and torque arm are out to. I even have the slave cylinder or whatever on the side disconnected and pulled up out of the way. When i went to lower the jack slightly to tilt the trans down for access to the top two bolts of the trans it didnt even drop an inch! It might not have dropped any at all! What gives?...Not my trans
Old Jun 10, 2013 | 09:02 PM
Re: trans & motor didnt tilt when jack was lowered
I forgot to mention that I DID remove the shifter plate or whatever you call it from the trans tunnel so that's not the issue
Old Jun 11, 2013 | 09:37 AM
Do you possibly have solid motor mounts? Even with rubber mounts, you sometimes have to push up on the front of the engine in order to tilt the trans down. Make sure your oil pressure sensor is not up against the firewall, and ready to break off (assuming you have a "late" 94, and not the "early" version with the pressure sensor above the oil filter).
Old Jun 11, 2013 | 09:50 AM
yeh, its the late model. just factory motor mounts. its tilted down in the past as far as i can remember. but ill take a look at the oil pressure sensor later today.
HectorM52
Jan 31, 2015 07:29 PM
alphaauto
Jan 22, 2015 08:02 PM
Jan 5, 2015 07:14 PM
Mikes 1994 z28
Nov 25, 2014 02:00 PM
