tranny shift problems??
Old Sep 26, 2004 | 10:47 PM
BigTedz28's Avatar
I have an a4 1995 z28 and i just had a new one put in about 4 months ago......as i start to take off in first, it feels like power loss, and wont switch gears like normal......it will rev higher, then finally shift when i let off the gas....?? whats the problem??? could it be my speed sensor???
Old Sep 27, 2004 | 12:25 AM
tfs95z28's Avatar
Re: tranny shift problems??
ive recently had this problem too, Im not too sure what that is either. i wouldnt mind finding out...
It seems to not want to shift until you let off the gas right??? Then once you let off a bit, it shifts, but only in first.
Old Sep 27, 2004 | 01:15 AM
S8ER95Z's Avatar
"i just had a new one put in about 4 months ago...."
Dont try to guess at it...I assume its under a warranty?? I had a 1 year on my trans buildup... If the tranny isnt even 6 months old take it to the trans shop and see what they say.
Old Sep 27, 2004 | 11:12 AM
tfs95z28's Avatar
anyone have any idea what that problem could be as to why it doesnt want to shift in first sometimes until you let off of the gas?
Old Sep 27, 2004 | 11:29 AM
S8ER95Z's Avatar
bad valvebody? low on fluid? burnt clutches?
Old Sep 27, 2004 | 08:08 PM
tfs95z28's Avatar
not the valve body or low fluid, know that for a fact, dunno about the burnt clutches
Old Sep 27, 2004 | 08:22 PM
S8ER95Z's Avatar
How does the fluid look? smell? texture??
Old Sep 27, 2004 | 08:32 PM
12SCNDZ's Avatar
Does the transmission have a shift kit? Your problem sounds like the 2-4 band is wasted. Hopefully you didn't have a Trans-Go kit installed, as this is a common problem associated with them.
If it doesn't have a Trans-Go kit, someone screwed up when they built it.
Frank
Old Sep 27, 2004 | 10:08 PM
tfs95z28's Avatar
i have a transgo shift kit installed. But does that 2-4 band have anything to do with the shift from 1-2? Cuz that is the only time that i ever have this problem, and even still it is rare
Old Sep 28, 2004 | 06:24 AM
12SCNDZ's Avatar
The "2-4" band is called that because it's the holding member in both 2nd, and 4th. It has to come on for 2nd gear. It can affect your 3-4 shift also, but not always.
Frank
Old Sep 28, 2004 | 09:14 AM
BlownF1's Avatar
What's the fix if you do have a Trans-Go kit? I recently installed one and mine is doing something similar and I haven't had a chance to call them...
Old Sep 28, 2004 | 05:12 PM
12SCNDZ's Avatar
There's nothing you can really do now, short of a rebuild. The damage all Trans-Go kits do is already done!
The fact is, I've been building racing transmissions for over 14 years....I've NEVER taken a 700 or 4L60E apart that had a TG kit that didn't have the 2-4 band and 3-4 clutches smoked.
The problem is, there isn't enough competent transmission builders out there. I don't use a "boxed" shift kit. I actually know enough about how a transmission works to modify it CORRECTLY without a "boxed" shift kit.
My only suggestion is, if anyone ever takes their car to a shop to have the transmission rebuilt, and they tell you they use TG kit, TAKE IT SOMEWHERE ELSE! They obviously don't know what they're doing.
Frank
Magenta_Hearts
Mar 29, 2017 08:54 PM
VF-124
Mar 16, 2015 08:14 PM
jackpawt883
Feb 26, 2015 09:04 PM
97SSdude
Dec 31, 2014 07:43 PM
tds1213
Nov 27, 2014 12:55 PM
