Tranny Fluid In My Coolant!!
Old Jun 4, 2005 | 07:20 PM
phinger23's Avatar
well, i found my issue...i need a tissue...
i have tranny fluid in my coolant.
wtf do i do now?
Old Jun 4, 2005 | 07:24 PM
EviLZ28's Avatar
Re: Tranny Fluid In My Coolant!!
Sounds like your radiator is junk. The coolant tank in the radiator that cools the trans fluid is leaking into the antifreeze coolant tanks. Hope it didnt let coolant into your trans. I seen this happen before and the trans got smoked.
Old Jun 4, 2005 | 08:32 PM
ibanez6rg's Avatar
Flush both systems and get a new radiator ASAP.
Old Jun 5, 2005 | 03:07 AM
phinger23's Avatar
damn radiator is a month old!!!! ahhhhh!!! more damn work. someone convince me not to blow this thing up.
Old Jun 5, 2005 | 03:52 AM
Black1995Z's Avatar
hang in there man! I had some probs with my car, tons of hours worth of labor and hundreds in parts just to get my crap taken care of.
Goodluck!!!
Old Jun 5, 2005 | 06:13 AM
Crazy95Z's Avatar
Man, just blow it up. I'll send you my car at the same time and we can watch a double explosion happen.
Old Jun 5, 2005 | 08:05 AM
Z28Nut's Avatar
Hey, could you guys yank the rears and send to me before ya'll blow 'em up? That way I could still drive my ride 'til the funds for the 9" are gathered. . .
It's definitely a leak in the oil cooler in the pressure tank. If it's only a month old the manufacturer should replace it. Unless it's a used rad you've only had a month. Any way, flush both systems but you can get a tranny cooler and use that in place of the P-tank (Rad) cooler. You'll need to block off the cooler lines to and from the Radiator or anti-freeze will leak out.
Old Jun 5, 2005 | 11:42 PM
phinger23's Avatar
would this cause me to have smoke coming out of my exhaust.
Old Jun 6, 2005 | 08:41 AM
phinger23's Avatar
Old Jun 6, 2005 | 05:14 PM
mattybz28's Avatar
No.
Old Jun 6, 2005 | 05:20 PM
phinger23's Avatar
just finished the rad install a lil bit ago, and no more smoke from the exhaust this time. a lil bit when i started it, and no more for about 15 minutes of the car just sitting there in idle
Old Jun 6, 2005 | 06:43 PM
87droptop's Avatar
Replace any hoses that would contact the coolant/trans mix. Upper rad, lower rad ect. Was the fluid in the trans clean?
Old Jun 6, 2005 | 07:17 PM
phinger23's Avatar
Originally Posted by 87droptop
Replace any hoses that would contact the coolant/a.f. mix. Upper rad, lower rad ect. Was the fluid in the trans clean?
dont know...havent chnaged that yet. ill have that done when i replace the head gaskets
blac94Z
Feb 15, 2021 09:43 PM
FieroLT1
Jun 26, 2015 08:43 PM
jmadoll
May 27, 2015 07:13 PM
91 Redd Sledd
Aug 25, 2002 03:27 PM
rncotton
Jul 1, 2002 10:43 PM
