trac controal
Old Nov 19, 2004 | 12:00 AM
Daniel6718's Avatar
trac controal
wat all do i eed to put traction controal on my 94z without it...wat parts are differant censors wires ect.
thanks
Daniel
Old Nov 19, 2004 | 12:55 AM
Z95m6's Avatar
Re: trac controal
Traxion controal sux. Most peeple take it of cause they dont want to hav it on there carr.
Old Nov 19, 2004 | 05:47 AM
ROLYZ28's Avatar
Re: trac controal
At What Price Would Such A Conversion Set You Back
For A Manual And Auto
Is There An After Market Supplier
Any One
I Dont Think Tc Sux Coz In Wet Weather It Sure Is A Blessing
Old Nov 19, 2004 | 02:25 PM
TW95Z's Avatar
Re: trac controal
To add traction control the way GM did it stock, you need lots of parts because they used brakes and throttle control to control wheel spin.
2 rear wheel sensors and wiring
2 reluctor wheels one on each rear axle (ABS only uses one sensor and reluctor in the differential)
2 brake lines (one for each wheel) that run all the way to the ...
1 Traction Control Module located right below your ABS module along with small pipe that connects the rear out of the ABS to the input of the traction control module, and the wiring harness.
1 Throttle control motor which requires a different accelerator cable and cruise control cable, and harness connection.
1 I believe the EBCM is different, but you'd have to double check part numbers to be sure on that. I haven't looked at the wiring diagrams for abs only but you may have some wiring to add the TCS relay to the underhood fuse box.
This link shows what I removed from my 95z.
http://www.pharmacy.arizona.edu/staf.../NoABSTCS.html
An easier solution would be to look for an aftermarket product that uses ignition timing to reduce power when wheel slip is detected.
Tim
SG66GAL
Aug 16, 2004 10:01 PM
BlackLT1_TX
Nov 25, 2003 05:19 PM
crYnOid
14
Sep 2, 2003 08:45 PM
Capn Pete
May 24, 2003 09:10 AM
Z064MULA
May 7, 2003 07:26 AM
