ABS inop , Low trac ???
Old May 4, 2003 | 12:17 PM
Z064MULA's Avatar
I went to the track yesterday and on my first pass I heated up the E.T. streets launched the car and when I went to slow down the ABS inop light and the low trac light came on. I went around to get my slip and I had ran a best ever 1.79 60 ft. and a 4.96 330 ft. (total time updated in sig) but now the ABS light stays on and the low trac light comes on when I hit the brake, the mph also fell off on every run after that, any ideas??? What have I broke or tore up? THANKS
Old May 4, 2003 | 06:49 PM
badass383's Avatar
Can't guess, scan it and get the code. Then you'll know for sure
Old May 4, 2003 | 08:48 PM
jim88iroc305's Avatar
Cool
I'll betcha a nickel he's not throwing any codes when he scans it.
Old May 4, 2003 | 09:22 PM
atljar's Avatar
Are the gears a new mod or have they been in there for awhile?
Old May 6, 2003 | 08:03 AM
Cool
Is the conditon still present all the time, intermittent or gone?
There is a TCS shutdown mode where an overtemperature condition such as braking at high speeds at the track will disable the TCS system but PCM will still monitor and light the TCS light on dash.
Old May 6, 2003 | 09:33 AM
DJ:BOTA's Avatar
From: NEPA 15min to stroudsburg, 30min to A-town, 45min to Wilkes-Barre
When I installed gears I had the same problem.
Old May 6, 2003 | 11:38 PM
ChuckZ28's Avatar
Bleed your brakes. mine did the exact same thing so I bled the brakes and the lights went away.
Old May 7, 2003 | 12:06 AM
mortal z28's Avatar
one time i was almost in a rear-end accident.. just wasnt paying attention then had to get on the breaks.. the abs kicked in and for a while the abs inop light was on but the next day it was magically gone
Old May 7, 2003 | 07:26 AM
teke184's Avatar
i've had mine go on from time to time. seems like i've related it to problems with a low battery (strange i know...could be just coincidence). but i know i pulled the fuse and it went away.
have you checked the connections on the abs and traction control sensor (whatever that sensor is called)?
speedracer1280
Sep 8, 2015 06:12 AM
TGGodfrey
Aug 17, 2015 08:43 PM
tnmotown
Aug 10, 2015 11:52 PM
alphaauto
Jul 26, 2015 04:40 PM
Noct
Jul 14, 2015 01:18 AM
