TPS and Fuel pump Q's
Old Sep 29, 2003 | 09:31 AM
ZaneO's Avatar
With the key turned I get ~.4 volts on the TPS and at WOT I only ~3.8
The TPS is brand new. Should I be getting 4 volts difference (~4.4)?
When I put a fuel pressure gauge on my car, I was getting a very fast pulsating in the line and pressure was down just a little bit. Is the pulsating a sign that the pump is going out?
TIA
Old Sep 29, 2003 | 08:24 PM
ZaneO's Avatar
Any help?
Old Sep 29, 2003 | 08:30 PM
RamAir95TA's Avatar
It SHOULD hit closer to 5 volts...3.8 sounds a little low to me.
And since you had a fuel pressure gauge, what pressure were you seeing?
Old Sep 29, 2003 | 08:57 PM
ZaneO's Avatar
Don't remember for sure, but I think it was about 40-42 psi.
Any suggestions why I'm not getting higher TPS voltage?
Voltage is the same with the new and the old TPS.
Old Sep 29, 2003 | 09:17 PM
Zeueses 97 RamAir's Avatar
I just fixed mine
at wide open throttle you should be at 4.3 if it is 4.2 2 and below it will throw an service light i know because i messed with it for about a month..... at idle you should be closer to 59 68 volts call me if you need help972 824 0793 angelo
Old Sep 30, 2003 | 06:57 PM
ZaneO's Avatar
ttt
Old Sep 30, 2003 | 07:24 PM
Ace_437's Avatar
Did you get the memo about the new cover letters on the TPS? We'll make sure you get another copy of that memo.
Old Sep 30, 2003 | 08:11 PM
ZaneO's Avatar
I get it.....funny, but of no help
Anybody have any ideas about the fuel pump?
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Black Sunshine/ 00SS
Sep 15, 2002 10:08 PM
