torque specs for manley sportsmaster 14103-8 rods?
Like it says! They have 3/8 8740 cap screws from arp installed, but no torque specs were supplied... I have some arp molly lube to use with them, so what should I torque them down too? I can't seem to find it anywhere on the net!
Cody
Cody
Re: torque specs for manley sportsmaster 14103-8 rods?
You need to get better at using Algore's invention
http://www.arp-bolts.com/Catalog/Cat...P2005_0024.jpg
Rich
Rich
well, not exactly what I needed... I emailed manley, they sent me the instructions. 55ftlbs with 30 weight oil, and they said NO MOLLY LUBE. I found that kind of wierd, but whatever. They should know thier rods I guess. Anyone else heard this?? Or torque thier manley sportsmaster rods to this spec?
Sounds right, and darn close to what is on the ARP chart. However, I do believe what ARP says and I use their moly lube and torque to their specs.
Rich
Rich
Originally Posted by A/G
As an alternative to the torque spec, did they also give a recommended bolt stretch spec? I'd question their knowledge if they didn't.
unfortunately I dont have a rod stretch guage. I dont build motors for a living, so I would buy it to use once, maybe twice. Not very economical. I know it would be the correct way to do it, but just not in my budget. I would hope the torque spces would be enough to get it right. If it wasn't, why would they advertise that as an acceptable method of tightening?
carguyshu
01-22-2017 11:19 AM
SpraydZ
06-07-2016 01:44 PM
