Torque Arm
Old Jun 4, 2003 | 05:35 PM
Green G0blin's Avatar
Torque Arm
i have true duals in the formy and i was wondering if the Torque arm will work with the true duals? cus i know with a driveshaft safte loop i have to manufacture and fabricate something to work, but a torque arm? will it work??? should have done research before hand
Old Jun 4, 2003 | 09:44 PM
uhhhhhh... which TA? If its one that replaces the stock design and pushes the front mount into the stock location on the tranny tailshaft, you shouldn't have any problems. If its one like the Spohn, where the front mounts in place of the "g-load" brace, and hangs low, you might have a problem.... but then we don't know exactly how you have your duals routed either.......
Old Jun 5, 2003 | 12:14 AM
i have the true duals dumps off under the car before the differential. and the torque arm i was talking bout is the BMR TA
Old Jun 5, 2003 | 05:56 AM
Depends on which BMR......
Standard BMR pretty much fits where the stock arm goes, up in the DS tunnel. Shouldn't be a problem if your dual fits with a stock TA. BMR Trac-Pak and BMR Xtreme require a front mounting bar across the chassis, and will PROBABLY interfere.
Stephen68
Parts Wanted
Sep 27, 2015 06:42 PM
autoxr166
Sep 25, 2015 04:21 PM
Jake Bialke
Sep 24, 2015 11:31 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Bxlt1
Sep 17, 2015 08:31 AM
