toqueing header bolts
Old Feb 1, 2006 | 03:30 AM
97formula808's Avatar
how do you guys actually torque your headers? i can't for the life of me fit a socket over the head to torque the pacesetters in. i tightened them w/ a wrench when i first put them on. i'm worried that if thier torqued differently, they'll warp. any suggestions?
Old Feb 1, 2006 | 04:08 AM
RE AND CHERYL's Avatar
Re: toqueing header bolts
Just get them all as tight as you can. When they leak, do it agian. I had to retighten mine a few times before they setteled in. Haven't messed with them for a year or so now.
Old Feb 1, 2006 | 07:28 AM
GreenZLT1's Avatar
I used a tiny open end wrench. No leaks.
Rob
Old Feb 1, 2006 | 08:51 AM
1quickTA's Avatar
Same here - just used a little (3/8 i believe) wrench to tighten them as much as I could. Make sure to check them FREQUENTLY during the first few weeks for retightening, then they should be fine.
Old Feb 1, 2006 | 04:05 PM
2000GTP's Avatar
Theres no real way to fit a bulky torque wrench in there. I just tightened them real good with an open end wrench. I check them periodically and they haven't backed out since the day I installed them.
Old Feb 1, 2006 | 06:45 PM
Jeff H's Avatar
I used a small socket for some of them and an open end wrench for others. You want to run the engine for 15-30 minutes to let the headers and gaskets go through a heat cycle and then come back later on and retighten. Take a short drive and then retighten after it cools. I put the Stage8 locking bolts on and I waited for about 5 heating cycles before putting the locks and clips on. No problems so far.
Old Feb 1, 2006 | 08:08 PM
izzyz28's Avatar
Ditto. Use a wrench and get them about as tight as you can. Tighten them again a few times over the next few days/weeks, and then check them every three months or so. I always find one or two that are backing out every time I check mine.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
maybe2fast
Mar 16, 2015 09:45 AM
SavageZ28
17
Jul 14, 2002 11:04 PM
