Tools for 02 sensor removal?
Old Jan 17, 2009 | 05:15 PM
  #16
Stl94LT1's Avatar
The 96/97 are different, they are OBDII.
Old Jan 17, 2009 | 06:55 PM
  #17
djskiggz's Avatar
LOL im blind. Nevermind I found the sensor. Yup the stupid mechanic replaced the wrong one. Dumbass!
Old Jan 17, 2009 | 06:59 PM
  #18
mdenz3's Avatar
7/8" or 22mm. I've never had issue rounding them off, but if you live in the rust belt, be ready for a fight.
Old Jan 17, 2009 | 07:00 PM
  #19
Stl94LT1's Avatar
It was probably easier to reach than the one that needed changed.
Old Jan 17, 2009 | 07:02 PM
  #20
twcblackhand6970's Avatar
mine has two also.
Old Jan 17, 2009 | 07:29 PM
  #21
sbs's Avatar
sbs
Unless you have codes, leave them alone.
While I am one who preaches 30-50k front O2 changes, there is absolutely no reason to change a rear O2 until it throws a code.
Old Jan 17, 2009 | 07:38 PM
  #22
andysc's Avatar
having the tool is the preferred way to go, but you can rent one from Autozone. You do need a 3/8 ratchet and probably a extension or two, but o2 sensors you don't really change a whole lot, so if you want to try to do it once in a while this may be the way to go.
tia
andy schuck
Old Jan 17, 2009 | 10:17 PM
  #23
Originally Posted by Stl94LT1
If your car has just one cat, you'll have three o2 sensors. If it has two cats, you'll have 4.
No. 93-95 single cat cars have only two O2 sensors, one in each branch of the Y-pipe (driver's side is actually in the base of the manifold), before the cat. There is no after-cat sensor on the single cat, OBD-I cars.
Old Jan 17, 2009 | 10:22 PM
  #24
Stl94LT1's Avatar
I was refering to the OP's 97. Guess I should have stated that.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
ChrisFrez
Feb 22, 2015 08:47 AM
squarehead
Jan 15, 2015 07:02 PM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
