too much valve spring pressure
Old Jul 23, 2009 | 03:47 PM
football4life's Avatar
I was just wondering if having too much valve spring pressure would cause any promblems. I bought a set of springs from a guy who says he builds lt1 engines in Illinois. I am now finding out what the specs of these springs are: 140#@ installed, 385#@ open.
I read on compcams site that the range should be between 105-135 installed and 280-350 open
Thanks,
Josh
Old Jul 23, 2009 | 05:13 PM
95Blackhawk's Avatar
what is the problem?
Old Jul 23, 2009 | 06:04 PM
Old Jul 23, 2009 | 06:52 PM
Stl94LT1's Avatar
I'm running 155/410 spring pressures with stock lifters, and no problems.
Old Jul 23, 2009 | 07:22 PM
96capricemgr's Avatar
Comp's rpm ranges are all low for the LT1, this leads to their spring pressure recommendations to be low as well.
IMO you are BETTER off with what you have than what Comp recommended.
Old Jul 23, 2009 | 10:52 PM
Thanks a lot guys
DirtyDaveW
Mar 15, 2015 07:01 PM
Roadie
Feb 16, 2015 10:34 AM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Jul 4, 2005 05:00 PM
